Old 05-19-2011, 03:09 PM
rohrt rohrt is offline
Question Rusty coolant and radiator flush
I had some really nast brown coolant in the radiator when I pulled my motor, enough to plug up the petcock when I tried to drain it.
Anyway its obviouse I will be flushing the system but I want some opinions on if I should use a flush cleaner.
Read about a wide range of different things to try:
Coke
Viniger
Preston super radiator cleaner
GM P/N 123465000 2 part cleaner
Lestoil
Oxalic acid + Neutralizer
Dupont 2 part flush.
spic and span
Permetex 80030 HD Radiator Cleaner
Looking for some feed back. I don't want to create a new problem.
Old 05-19-2011, 04:57 PM
GT182's Avatar
GT182 GT182 is offline
Those should work ok but.... I'd take it to a radiator shop and have them boil/flush it out if it's that bad. They will get it clean and serviceable again. And they'll let you know if it's still good to use.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 05-20-2011, 12:05 AM
Pontirag Pontirag is offline
I 'm surprised nobody mentioned drano. It will cleane out your cooling system all right but you absolutely must flush it completely afterwards, and plane on replacing the water pump.
Old 05-20-2011, 09:46 AM
Drano, that's a new one to add to the list. The issue I have with the "experimental" treatments is no one really know what it will do to the gaskets or water pump seals.
I pulled the pipe plugs on the block last night and drained the remaining coolant. I guess it wasn't as bad as I thought. Still a bit brown and cloudy but not like it was all sludge. I could still make out the green in the coolant. I think I will go with the two part cleaner and flush it out when I get it back together.
Old 05-20-2011, 05:04 PM
PJPONTIAC PJPONTIAC is offline
I just cleaned out the system in my TA the other day. I put in about 16 oz of dishwashing detergent and let it run with that for a little while, then drained it out. It has no more brown rust in the coolant system.
Old 05-20-2011, 07:57 PM
GT182's Avatar
LOL.... Is it still blowing bubbles? That's one I've never heard of.. glad it worked ok.
Gary
Old 05-21-2011, 02:33 AM
its not experimental and it works. its extream but it works
Old 06-23-2011, 01:51 PM
I read that there are acid cleaners and detergent cleaners. I want to use an acid cleaner as I think my cooling system needs it.
I'm kind of leaning to the Vinegar solution now. There is a tone of info on it. Seem pretty strait forward. Has anyone tried this. I'm not seeing a downside yet.
Old 06-23-2011, 02:05 PM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
I have used Rydlyme in the past with good success. Bio-degradeable and does not seem to harm seals.
P.O.S.I - It's not just a club...it's an addiction!
