I have never seen this happen. Engine is a 400 w/48 heads running a Crower 60243 cam with Ferrea valves and new springs/keepers, ARP rocker studs, etc. installed a couple years ago. Switched to stock rockers due to Pure Stock requirements and used the Hand adjusting method with poly locks. This was done a couple months ago and car had been driven many times since then.
This happened a couple weekends ago. I had been out on a nice (sometimes spirited) drive through horse farm country. Probably close to 60 miles. Was sitting at a stop light idling fine when engine developed a miss. No noise, just a miss. I thought since it was warm maybe the carb had loaded up. Tried to clear it but no change - had a dead cylinder. Drove the car home and this is what I discovered. Pushrod was fine and lifter still in bore. Installed another rocker arm and readjusted and started up and running strong as ever now. So what caused the failure? Rocker was old and failed or incorrect adjustment. I did not have an excessive amount of valve train noise at anytime prior or after the failure. Thanks, Tom
1969 Firebird 400 Convertible "We have got but one life here. It pays, no matter what comes after it, to try and do things, to accomplish things in this life and not merely to have a soft and pleasant time." - Theodore Roosevelt "Light travels faster than sound. That is why some people appear to be bright until you hear them speak." - A father's words of wisdom to his children |
Maybe the rocker arm slot does not have enough travel for the lift of your cam.
SEVEN UPS 2.0 TAKING THE THIRD DEGREE ONE STEP FURTHER 2016 1/8 MILE 7.0 @ 100 MPH 406 B&M MINI BLOWER |
The stock rockers were not long slot and probably did not have enough travel to cover the cam you running. I've seen this happen to someones SBC when they used stock rockers with a performance cam. In thier case it also snapped off the 3/8's rocker studs...
Are they GM rockers or aftermarket replacements?
The aftermarket ones are junk. |
Happened to me way back in the 70's...a couple of times...always bent pushrods along with it though...and always at high rpm's. Nice "bang" sound too. Performance cams w/stock rockers...risky
X 2 Spring pressure, cam lift, slot length for cam lift, 50 year old USED rocker, to name a few. |
I had Sealed Power brand do that to me back in the late 70's, early 80's. Engine was 400 w/ Lunanti Ram Air III cam, 1.50 ratio. I had three or four fail on me back then. Not sure if it were brand related or not. Went to Harland Sharp full rollers and never experienced another negative valve train issue. Street engine builds, nothing agressive (High 13 to low 14 second 1/4 mile stuff).
Tim john--- |
Lifter pumped up, due to "Spirited Driving", valve is open and when piston comes up (with the lifter not bled down, it smacks the valve. There is no "give" therefore the thin metal of the rocker pulls apart.
So how did you adjust these rockers with your set-up? Tom Vaught
I dont see any bluing or such,so the failure almost certainly was'nt heat related.
Next most likely culprits are uneven wear or mechanical interference. If those stamped rockers were run with any other cam than what your running now,then uneven wear becomes a very likely possibility,often that manifests itself more @ the pushrod cup (PR punches thru the cup),but it can manifest in the fulcrum area as well. Stamped rockers really are'nt interchangeable/re-useable like roller rockers are,new builds should always get new rockers,and if you change cams,you should also change the stamped rockers as well,as the wear patterns in those stamped rockers tend to take a "set" and they dont always fare that well if those wear patterns change. Some may also blame those grooved rocker balls too,but I dont think those are what caused this failure,not unless the rockers were used,and the grooved balls were new,as that would be the same deal as mentioned ^^^^ above. I also agree with those that said to check the rocker slot travel too,especially if using a higher than OE lift cam or such (and of course the Crower #60243 cam is). Would help to what valve springs ya'll are using on this? Also,were they new rockers,if so what brand were they? ![]() Bret P. |
Thanks for the information. The rockers were used, stock items. Valve springs were new with everything else - came from Kaufman and matched to the cam.
Valves were adjusted by tightening the poly lock until the pushrod just stopped spinning by hand then almost a 1/2 turn, lock down the hex nut and then tighten the poly lock. Didn't consider the lift of the cam causing the rocker slot to have too much travel. There were no marks on the rocker stud. Will have to take a look at that aspect. I found a set of new Sealed Power rocker arms on my shelf. Maybe time to replace them all with the new ones. Now I need to find a set of the grooved balls. Tom
That comment was kinda confusing the way you stated that. Anyhow,there may not always be witness marks on that sorta deal,those ARP studs are pretty tough (read:hard) material compared to those stamped rockers,so it's entirely possible that the rocker would've been the piece that took any/all of the punishment of said contact. Quote:
Me personally,I really dont have a preference one way or the other,I'll use whatever comes with the rockers themselves. But that's often one of those deals some feel pretty strongly about,so that topic might indeed get some pro & con comments here. Without knowing exactly what springs & pressures were used it'll be hard to have much of an opinion on that as a possible contributing factor for that failure. But yeah,used stamped rocker arms are always sort of a crapshoot in terms of if they'll hold up well or not,sometimes they do OK,sometimes they dont last very long at all. ![]() Good luck with it. Bret P. |
Bret,
Yes, that is what I meant to say - thanks for clarifying it. Appreciate your help/insight. Tom
I'm surprised no one mentioned checking for coil bind. The amount of clearance at full lift varies depending on whom you ask. But everyone agrees that it should be between .040"and .060". I lean toward the greater clearance for the street because our bigger valves are heavy and you're more apt to have lifter pump-up when the springs lose strength. I would never have less than .050.
The slots being too short can definitely cause the problem, as well. If you look at the stud, it should be readily apparent if that's your problem, or not. You can probably tell by looking at the remnants of the rocker, also. The metal in the rockers is relatively brittle. If they're dropped it can start a crack which will run.
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher Last edited by Stuckinda60s; 05-24-2011 at 01:43 AM. |
Like I said,without knowing exactly what springs were used,any discussion of those as a potential contributor would be pure speculation @ this point.
If a spring like the recommended Crower # 68404-16 springs were used with the "stock" length valves for those #48 heads and that Crower #60243 cams,one would almost certainly run into retainer to guide clearance problems long before they would ever run into any sorta coil bind issues with those Crower springs. And the retainer to guide (or seal) clearance mostly depends on what guide bosses those heads have and what VS seals they are using,if they are using PC style seals with the "cut down" guide bosses (and they almost certainly are as the Ferrea valves usually dont come with the second groove in them for the OE style O-ring seals),then IMO there should be plenty of retainer to guide/seal clearance for that Crower #60243 cam's lift. The only springs that really would have potential problems with coil bind would be a true "stock replacement" spring,and I seriously gotta doubt that KRE would be dumb enough to sell a spring like that to a guy that's using the Crower #60243 hydraulic cam. So IMO that's probably not the problem. But I could be wrong,,,I'm not the one that put it all together,,,so I dunno really... Bret P. |
Speculation? No need for speculation, at all. Realistically, it doesn't matter what springs were used or are supposed to have been used. It's very easy to check and one of the first things I would look at.
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher |
Thanks for the continued responses. Was out of town on business Monday and Tuesday. Dug out the receipts from Kauffman this morning which will answer the remaining questions from you guys.
Valves - Ferrea 5144 and 5143 Crower 68404 springs Comp 740-16 retainers Comp 611-16 locks Crower 66056 lifters ARP 135-7101 rocker studs Tom
X2-My old 409 with a big cam in high school would routinely break rockers(once sendoing a pushrod through the valve cover in the staging lanes and probably caused a dropped valve on a street race-drove it home never found the valve head. Machine shop setup the valve springs. Well fast forward 30 years when I have a vale srping tester pulled them off the shelf and they were in coil bind.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Sorry guys,but there is no way a #68404-16 spring is coil binding with that #60243 cam.
Like I said,with stock length valves the retainer would likely hit the guide boss before those springs would coil bind. Coil bind for the #68404-16 springs is like .950",that means installed @ 1.600" IH you'd have an easy .600" lift clearance and still maintain a "safe" .050" spring clearance. And yeah before anyone asks,I've had sets of these #68404-16 springs checked in the past,and they were pretty much spot on what the spring specs said they would be. He can go ahead and check 'em if he really wants to,but IMO he'll be wasting his time doing that,as those are pretty much the best springs you can find for the 1.600" IH. FWIW Bret P. |
Brett,
I try to listen to the experts and that is why I bought all new cylinder head parts and cam from Kauffman (based on Cliff's recommendation). He knew how I was going to run the car and matched everything up. I then took the parts and heads to a local cylinder head guy (all he does) and he performed a valve job, put everything together, checked spring rates and installed height and said no issues. I drag race the car on occasion running 14.2's with terrible 60 foot times due to wheel spin. I keep the rpm's at 5,550 and have my rev limiter set at 5,800 rpm's. Feels like it would keep pulling through 6,000 rpm's! Took the car out for about 45 minutes today and running great. Thanks for all the input. I will keep an eye on the remaining rockers and go ahead and install the new Sealed Power set soon. Tom
