Old 05-30-2011, 08:41 PM
form74's Avatar
form74 form74 is offline
Default Bypassing Heater Core, ? on Fluid in Heater Core
I'm planning on bypassing the heater core ( Bottom hoe is really bad and it's easier right now to just bypass it ) and replacing the coolant with water for the track. What is best way to leave the Heater core, flush that also and then blow it out with air and cap it.
74 Formula
Below motor destroyed last fall
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
New motor
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Results will be posted after the track
Old 05-30-2011, 08:51 PM
Pontirag Pontirag is offline
cap it to keep the mud dawbers out. just run a hose from the front to the rear. its more reliable than those caps wich blow out without much notice. Also pure water is not the best idea. coolant antifreze is best, mixed with distilled water.
