Old 05-31-2011, 12:27 PM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Default Newer lower radiator hoses
Are springs no longer necessary with today's newer lower radiator hoses? Anyone use the the newer hoses (without springs) with success?
Does O'Reily or NAPA sell decent hoses?
70 Formula 400 Auto non-A/C
Wanted: 1972 Formula HO - leads very much appreciated.
Old 05-31-2011, 05:37 PM
DaveD DaveD is offline
I just picked up new hoses from carquest (gates) and the lower has a spring inside.
Old 05-31-2011, 09:03 PM
GT182's Avatar
GT182 GT182 is offline
That's good news Dave. I've been looking for a new lower hose with the spring in it. Can't find one around here with it included, and can't buy just the spring either.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 05-31-2011, 10:29 PM
66Post's Avatar
66Post 66Post is offline
I saved the old spring and put it in the Repo numbers hose I bought. Give it a shot (sans spring) and let us know what happens.
Old 05-31-2011, 11:30 PM
Pontirag Pontirag is offline
I also have found that a spring is a sometimes option. usually my old spring is too rusted to re use.
what I do is get a spool of safety wire and some safety wire pliers, (yea like everybodys got that all layin around). I get about a 8 foot length of wire and twist it up with the pliers. you dont need the pliers though. but I twist it up untill I get about 8-10 twists per inch. then I wrap it around a 2 inch diameter cardboard tube in a spiral fashion. when i am done the stainless wire has work hardened to give it springyness and I insert it in the hose. No more colapsed hose and being stainless it is reusable.
Old 06-01-2011, 10:25 AM
Pontiac62's Avatar
Pontiac62 Pontiac62 is offline
I bought a spring from Ames about a year ago.
Les
Old 06-01-2011, 01:42 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
I found the Gates lower hose with spring at my local NAPA. I have a lower without the spring on the car now and have not had any problems. I keep the new Gates hose along with new belts, coolant, and oil, as kind of an emergency kit in my trunk. My car is a daily driver that frequents country roads so a little forward thinking is a good idea I think.
If I ever have a hose collapse I will return to post the information on this thread.
Karl
Old 06-01-2011, 03:29 PM
how do you know you dont have problems? they usually collaps at higher rpms
Old 06-01-2011, 03:57 PM
On days like today when temps are in the mid to high 90's I still dont have problems with overheating. And by high rpm's if you mean 4000-5000 my car rarely sees those speeds so I guess it would then be a moot point. So I guess in that sense I don't have problems.... Well, not the car anyway Maybe it does collapse for a moment but I wouldn't be able to tell if it does or not.
Karl
Old 06-02-2011, 12:21 AM
I was just curious, If you put small children in the engine compartment to whatch it while you drive up and down the freeway? They have a short attention span and sometimes it gets messy if they fall into the fan.
Old 06-02-2011, 12:45 AM
Unfortunately I don't have any children and my brothers and sisters know that if I'm asking to borrow one of theirs I'm damn well up to no good!
I wonder if their would be enough light under the hood to mount a small camcorder and monitor a hose like that?
Karl
Old 06-02-2011, 05:25 PM
less clean up too.
Old 06-03-2011, 05:23 PM
Old Goat Racer's Avatar
Got a part number?
Everybody knows somthin.
Nobody knows everything !
Old 06-03-2011, 09:02 PM
Originally Posted by Old Goat Racer View Post
Got a part number?
Gates #20854
Old 06-04-2011, 12:51 AM
Gates #20854
Which application is it for?
Old 06-07-2011, 05:26 PM
78 formula
Old 06-10-2011, 01:46 PM
No wonder it wouldn't fit my GTO. But it should fit my 78 TA.
Old 06-10-2011, 11:09 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
PY carries the spring if anyone just needs the spring.
Old 06-14-2011, 01:02 PM
GT182's Avatar
I went over to CarQuest the other day and bought a Gates lower hose. This one is the ribbed heavy duty hose that needs no spring. It's one tough hose and fits perfect. I don't mean to take away from Chris selling the springs but if you need one in a hurry that's the hose to get.
Gary
Old 06-14-2011, 03:14 PM
Ccass's Avatar
Administrator
Not a problem at all. I won't be retiring any time soon on these hose springs. I hadn't even thought about the ribbed hose. 5-6 years ago, most GTO owners wouldn't get caught dead with a ribbed hose but now it's all about having fun with your car. That makes this hobby a lot more fun for us as well.
