Old 05-31-2011, 01:09 PM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Default Recommended cooling parts
I have a 70 Formula 400, 4spd with A/C. I'm rebuilding the 400 and would like to know what is recommended (brand/part #s would be great) for the following cooling components? Rebuilding with 4" stroke, mild ported #12 heads (compression around 10.5), stock intake/exhaust manifolds, Q-jet and 2.5 exhaust pipes. Factory radiator and fan/clutch. Do not plan on using an overflow system. Weekend/car show driver.
1) radiator cap
2) radiator hoses
3) thermostat
4) water pump
70 Formula 400 Auto non-A/C
Wanted: 1972 Formula HO - leads very much appreciated.
Old 06-05-2011, 02:28 AM
Any input would be appreciated. I will be reusing my existing water pump.
Old 06-05-2011, 08:59 AM
stucky2947's Avatar
stucky2947 stucky2947 is offline
I have a similar build in my '62 GP, and I have found that my stock radiator did not cool well with the high compression. I bought a Griffin aluminum radiator and now she runs 180 - 185 all day in the heat of St. Louis summer. I used the radiator cap that came with the Griffin, I think it is a 14 psi cap. I am running a 160 degree thermostat and use regular ol' radiator hoses from Napa. (I had to find ones that work in my situation since I put a '69 motor in a '62 car.)
Make sure you check the clearance between the divider plate on the water pump, it should be a little less than 1/8". Modify if necessary and use the gaskets when checking. If you do a search on this subject, you will find lots of good info.
Mike Stuck - "Stucky"
1962 Grand Prix, 408 w/tripower, ported / polished #62s, TH400, 3.42 posi
