Old 05-31-2011, 10:47 PM
riceslayer's Avatar
riceslayer riceslayer is offline
Default 73 LeSabre with P455
Thinking of swapping the B for a P... anyone know about the mounts?
Old 06-18-2011, 04:08 PM
If it has the big rubber mounts on the frame I believe they will fit the Pontiac engine mounts of that vintage. The problem is that they will have to be moved. If you dont have the same type mounts get both the engine and frame mounts for the Pontiac and bolt the on to the motor and set in the frame. Connect the Buick trans up (it fits) and see if there are already holes in the frame. If not just drill holes ond bolt in.
Old 06-26-2011, 12:28 AM
riceslayer's Avatar
Thanks GR1, it is my friend's car and now he wants a BBC, good for me since I have one that I do not need anymore... I guess it would be about the same process? BTW, do you know where to get a mild roller for a BBC? Also intake, AFB carb, intake, headers, etc?
