Street/Strip!
Well a week ago I just got my engine installed back into my black "Punisher" 69 GTO from one of it's many transformations. It was first a raw 463 CI, solid roller, 87cc E-head engine, then it was a same combo 6-71 blown, then 8-71 blown, then pulled and placed in my other GTO 8-71 blown, then taken out pulled apart and freshened and put back together raw with a few minor upgrades and placed back in my other GTO for a summer of racing and then pulled and had stand duty for a couple of months till I could get it back in the black car. Since it's a pump gas, non filled engine and it has highway friendly 3.73 gears I decided to drive it to the track (65 hilly, curvy miles) on Saturday in 97 degree heat and make a few passes. Stopped at the local non-ethanol station and filled up with 91 octane and had an uneventful drive to the track, engiine got no hotter than 190 on the mountains and everywhere else it ran 170 degrees.
Once I got to the track and paid in for TNT I went and parked next to some friends and switched rear tires out to a set of old Hoosier drag radial 295/65-15's I had on some old steel chrome reverse rims. When they called TNT I was the last one to the line so had a solo and did a nice little burnout and pulled up to the beam, staged, yellow, yellow, yellow, leave..., leave.... nothing but rev limiter. WTF! Didn't hear anything weird so shut it off and got out and pushed it back with help from lane guys... weird clunking noise? gotta be the rearend... Get it back to the pits, jack it up and Passenger side tire wobbles and spins with no resistance. Broke PS axle but luckily C-clip eliminators did their job well. Called Brother in Law and he brought his trailer. We watched races and then headed home... For some reason everything was so raw and felt so right and seemed so old school that I don't ever want to trailer that car again unless it is broke. Saving for new axles... Drive em folks! PS - this engine went 10.28 @ 130 in my other GTO at Tulsa Pontiac Race in 2010 and was the engine I beat Dave Anderson in the GeeTo Tiger with so it makes a little bit of HP...
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
A man's got to know them 8.2 10-bolt limitations.
I think its the year to break shi*! ... Sorry
12 Bolt... Factory 30 spline axles but did have C-clip eliminators, Factory 1966 3 series posi from a SS 3396 4 speed Chevelle totally rebuilt with new clutches, spiders, and springs...
street/strip cars have to ride the hook too....
perhaps the street tires needed to stay on....
Yep... All the supporting pieces other than the engines... So far I got a Transmission, Drive Shaft, and Axle this year between my 2 cars... May the torque be with you...
Awe heck I knew it wasn't an 8.2 butt hey, it just sounded better.
Busted a Switch-Pitch Converter, but I dunno when. Coulda been October 2006. |
Ouch! No doubt the year of broken parts. At least the damage was minor and the repair relatively easy.
Are we going to see some Mosier axles in your future? I've been running them in my 8.5 for quite a few years now, they came with "C" clip elims, no issues to date.....Cliff
$244 from Summit...
Reminder: I COULD be persuaded to sell the Strange 3.54:1 Dana60 in me 68GTO. Rear Discs and...
Half-Inch Studs
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Has anyone had any good experiences with pressing off a c-clip eliminator and then pressing it on another axle without teaing it up... Strange brand?
A buddy wanted to do that on his camaro and they couldnt do it so he had to spring for another c clip eliminator kit.
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
We pressed it off and got it on another axle. I drove it about 100 miles yesterday and last night and all seems to be good. True street/strip car heavy on the street...
Nice!
Street/Strip!
Picture someone took of me cruising with my grandson this weekend...
cool car for sure
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
damn that's nice, might have just pushed me back in the direction of another blower car......
Low 10 sec engine, stock 12 bolt axles did not stand a chance. I broke 31 spline (9") Mark Williams axles with a high 10sec 455.
I even broke the 1/2" ARP wheel studs once. Got lucky, did it backing up out of the pits to make a run. Why it did not happen at the line or at the big end. Could have gotten real ugly. Went to 40 spline, gun drilled, star flanged Moser axles with 5/8ths studs. Overkill, maybe for a 11 flat car. But I broke3-4 9 inch rears, couple T400s but the 455 is still going strong. (1990) |
add one of these for pre-load on the third member caps and you're done. I have this on the '79 trans am and have zero issues with stock rearend and running drag radials. My problem is splitting cases on 4 speed trannys. .....but the rear stays together.
http://www.jegs.com/p/LPW/LPW-Ultima...44455/10002/-1
Home of WFO Hyperformance Shaker induction. |
I have strange 30 spline axles and a rear end girdle from moser I just installed last night..
