Old 06-18-2011, 05:43 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Default Paint removal from hood scoop inserts?
I have and extra pair of hood scoop inserts for my 69 GTO that I cut open. Whats a good way to strip the old paint off? Can I use a chemical stripper?
Thanks,
Eric
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 06-18-2011, 06:06 PM
400 4spd.'s Avatar
Chemical stripper will work fine, just rinse it thoroughly afterwards. If you can give it a light blast with media afterwards it will give it bite for primer.
Old 06-18-2011, 09:14 PM
Cammer-6 Cammer-6 is offline
easy off oven cleaner will work
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 06-19-2011, 08:17 PM
Thanks, used a paint stripper I had and then a red scotch brite pad to get the last of the paint off and rinsed with water and a clean red scotch brite to clean them up.
Eric
