Old 06-19-2011, 03:53 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Default Snowflake wheels
I am trying to refinish my wheels and hope I did not make a big mistake. I put the wheel into my bead blaster to clean it up. How do I polish the front as now they are dull? Should the front be taped off prior to blasting as well as painting?
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 06-27-2011, 10:54 PM
pippintook pippintook is offline
On my 78 Trans Am WS6 Snowflake wheels the spoke faces have a light machining finish to them. They are painted in between the spokes. I think the area in between the spokes was just a cast aluminum finish (prior to painting). The outer wheel area (where spokes end...to the wheel/rim edge are polished).
So, I am guessing if you bead blasted the whole wheel, you would have lost the machined
finish on the spokes and the outer wheel polished area would look a bit dull. I would guess that bead blasting would not matter to much for the area in between the spokes...as this area gets painted anyway.
Restoring the machined finish on the spoke faces might be tough to do by hand...I know
there are guys that remachine the face of the spokes when they do a full wheel restoration. For the outer wheel polished area - maybe an aluminum polish...like mothers?
Hitman's Page has some good info on wheels
http://www.78ta.com/wheelspec.php
An tips for restoring wheels
http://www.78ta.com/resto/rims.htm
Old 06-28-2011, 10:39 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I SAND BLASTED a set-talk about alot of work-had to get flapper sand wheels then polished them.
Skip Fix
Old 06-28-2011, 12:03 PM
462-6spd 462-6spd is offline
When I did mine I first stripped off the original paint & then used buffing wheels & polishing compounds I obtained from Eastwood to remove all the machine marks. I then masked all the spokes - yes it took hours and hours - then I re-sprayed them gold.
