Old 06-27-2011, 08:35 PM
Martin1264's Avatar
Martin1264 Martin1264 is offline
Default Oil/Temp Gauge
Question...My Water/Oil Temp Gauge for my 73 seems to be off, looks lik my car is running hot but it's not.....Does anyone know what other years would work with my 73
Thank you.....
1973 Trans Am
Cameo White with White interior
Auto
Old 06-27-2011, 08:46 PM
SD73's Avatar
SD73 SD73 is offline
Originally Posted by Martin1264 View Post
Question...My Water/Oil Temp Gauge for my 73 seems to be off, looks lik my car is running hot but it's not.....Does anyone know what years are interchangable with my 73
Thank you.....
I believe we discussed this before. As I recall the pre '74s temp gauge reads 10 degrees higher on the face and has a temperature sender calibrated to match.
Old 06-27-2011, 10:50 PM
Ram Air IV's Avatar
Ram Air IV Ram Air IV is offline
74-77 should be the same...
Old 06-30-2011, 10:21 PM
Martin1264's Avatar
Thank you for your responses....Looks like it was not the Gauge after all. I had installed a new sending unit and that was causing the bad temp reading...my friend had a older one that we installed and that did the trick.
1973 Trans Am
Auto
