Old 06-28-2011, 05:13 AM
tigergto's Avatar
tigergto tigergto is offline
Default Gas Smell
After driving my 71 GTO and parking it in the garage I get a stong odor of raw gas. There is no visible leak. I also seem to be getting poorer gas milage. Any ideas of what to check?
Old 06-28-2011, 06:43 AM
F ROCK's Avatar
F ROCK F ROCK is offline
on mine it was the rubber hose that goes to the fuel pump.
Old 06-28-2011, 10:08 AM
Lemans1970 Lemans1970 is offline
I had such a problem a while back. Turns out it was the screw-in carb fitting that held the bronze fuel filter. Over time threads had become compromised such that it no longer sealed well. Fuel on a hot engine not good and hard to identify due to rapid evaporation.
Old 06-28-2011, 10:22 AM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
Check your oil; bad fuel pump membrane can fill the crankcase with fuel.
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay"
1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always.
Old 06-29-2011, 12:45 PM
2002Z4CSS's Avatar
Check to see if the bowl plugs in the carb are leaking fuel. If so you can put some epoxy on them to reseal the plugs.
1971 Pontiac GT-37
Old 07-08-2011, 05:03 PM
tigergto's Avatar
Checked today could not find any visible leaks. Idled the car 10 -15 minutes did not see or smell anything. Only when I come home after a drive and park in the garage close the door and when I go back out a short while later, strong gas smell. I didn't go for a drive today but that is when it happens. Any ideas?
Old 07-09-2011, 06:45 AM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
It might be the float. Does it appear the fuel is dumping from the bowl? After you shut if off, take the air cleaner off and see if you can see the fuel oozing down. I think, if you don't have anything hitting the ground it's probably the carb. That darn ethanol.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 07-09-2011, 04:07 PM
HUMBLER's Avatar
HUMBLER HUMBLER is offline
I had a leak at the top of my gas tank...
1969 Judge (Liberty Blue / Blue, 4SPD)
Old 07-12-2011, 05:45 PM
lazlo's Avatar
lazlo lazlo is offline
Check your vent tube... make sure it is the corrct one and installed properly or you can slosh gas out of the tank everytime you take off... had the problem with my 68...
[SIGPIC][/SIGPIC]
http://www.gogtoaa.com/leibys%20rides.html
Old 07-12-2011, 08:21 PM
tigergto's Avatar
Seems to be gas dumping down the right primary. Thanks everyone for helping.
