Does anyone have a good 1 bbl carburetor? Thanks Bob
I forget who I gave one to in Calif. It wasn't his problem. He may still have it.John
Whats wrong with the one you have?? Kits are available. Easy carb to rebuild.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
I think John is referring to me. His carb is currently on my car. Problem is, I moved recently and can't easily lay my hands on the other one. I'll check this weekend.
The one I have has a dead stop when you press on the gas. I did rebuild it. There was another one that came with the car so I rebuild it, no dead spot but the car would not idle. So I thought I would try one more.
Have built a BUNCH of these carbs down through the years. Usually a dead spot is just an adjustment to the accelerator pump linkage. 50 year old part gets wear at the linkage pivot points/sloppy. I bend the linkage till the pump starts working just as the throttle opens. Wont idle is usually a plugged idle circuit passage. Hardest thing with these carbs is rebushing the throttle shaft.
Double post.
Thanks Keith. I will try and mess around with the accelerator pump linkage. Will let you know how it work out.
