I'm looking for the frame measurements right in front of and right behind the transmission crossmember. Measure the inner opening of the C section of the frame from a 68 or 69 2 door hardtop that is straight and clean. Mine is bent up from a jack being place there at one time. On the driver side I get 2 1/2" in front and 2 1/4" behind. Passenger side is 2 3/4" at both. My front drive shaft yoke is hitting the floor pan when more then one person is in the car. Also does anybody have any good ways to straighten it back out with the fuel and brake lines still in place. This is for my 69 GTO.
Thanks, Eric
Eric 1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60' 1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85 |
If you have fax access,I can fax you a blueprint.
I don't have access to fax machine. Thanks.
