Old 07-15-2011, 10:11 AM
punisher7's Avatar
punisher7 punisher7 is offline
Angry New exhaust issues
Now that I'm up and running I want to get my Catalina's exhaust taken care of. The guy that owned this Catalina must of had a blind guy with no arms weld this crap together. It is extremely low and when I pull in and out of my driveway I bottom out. I also bottom out when going over a bumpy road.
I have the car in to get the exhauat looked at and I'm told that 2 1/4 pipe wont fit over the crossmember and when they redo the exhaust it wont be much higher that what it is now.
Anybody ever have dual exhauat run on a 63 that wasnt dragging on the ground?
They want $350 to bend up the pipes. Any input would be appreciated.
Old 07-15-2011, 10:40 AM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Headers or manifolds?
Does Pypes or Ram Air Restorations have a system for 63 fullsize, ideally with a X crossover?
On my 65, I have RARE's long branches with their 3" head pipe and X crossover, then 2.5" intermediates, stainless Ultraflows and 2.5" Pypes tailpipes. I did have to ditch the factory trans crossmember for one taken from a 72 Bonneville, slightly modified for fit. It had more distance between the humps, gave more exhaust pipe clearance.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 07-15-2011, 10:54 AM
Deadhead's Avatar
Deadhead Deadhead is offline
That is crazy stuff. I have only 2" duals on my '63 wagon run above the crossmember, but there is at least 1 1/2 - 2" between pipes, the cross member and the floor. Stock manifolds. Should be no problem for a competent shop to get them above the crossmember. My tranny would scrape before the pipes.
Here are a couple of Pics.
ID:	249784   Click image for larger version
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 07-15-2011, 12:52 PM
63 Pontiac's Avatar
63 Pontiac 63 Pontiac is offline
Shouldn't be a problem, I had 2.25" pipe running over the crossmember on both my 63's with slim-jims.
Old 07-15-2011, 02:06 PM
mviker's Avatar
mviker mviker is offline
You might want to consider another shop. It's amazing how some places have no idea how to work on our cars. The first exhaust I had put on my car was so messed up, I had to go to another place and have it replaced entirely. They went so far as to alter my rear control arms because they couldn't bend the pipes right. I was ready to kill after I saw what they did. Second shop got it right.
Old 07-15-2011, 02:17 PM
punisher7's Avatar
Well its good to hear that it can be done, just a matter of finding the right person for the job. I will shop around this week and see what I can come up with. Anybody know of a good shop in southestern WI that does good exhaust work?
Old 07-15-2011, 03:52 PM
mkoser's Avatar
mkoser mkoser is offline
I'd avoid any of the big chain muffler shops, and look for one of the "low-rider" style shops you might find in the lesser desirable part of town.
I had some work done, not on my Pontiac, but on a Bel-Air I used to have. It seems as if they liked the car, and wanted to do a good job on it, at an honest price.
I assume they would respond to your Pontiac the same way.
Good Luck,
MK
Old 07-15-2011, 04:54 PM
punisher7's Avatar
I have manifolds on the car.
Old 07-15-2011, 07:19 PM
BigAquaBonney's Avatar
BigAquaBonney BigAquaBonney is offline
Try Wisconsin Muffler on Janesville Road. Gene and another guy there can do it, I'd bet. It should fit.
Old 07-15-2011, 07:41 PM
punisher7's Avatar
Thanks! I'll call them tomorrow.
Old 07-16-2011, 09:13 AM
Engine-Ear's Avatar
One year I needed new duals for four of my cars...all of them got manifold to tailpipe systems added, and I supplied Walker 17747 (highly recommend these for your '63, BTW) and I took them to four different places to gauge their work / prices.
By far, the BEST work was from Mike's Automotive, he's at 102 North Chicago Avenue, South Milwaukee, WI 53172 (so he's even close-ish to you).
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 07-16-2011, 10:51 AM
I concur with Engine-Ear, Mike's does good work. Didn't know that he had the pipe bending capabilities, etc.
Old 07-16-2011, 07:39 PM
punisher7's Avatar
Thanks for the info about Mikes. I will stop by there later this week.
