Old 07-27-2011, 08:39 PM
71ModelJ's Avatar
71ModelJ 71ModelJ is offline
Default Cyl. Head question
Got a set of Pontiac heads that I want to block the heat crossover on. I know a lot of them are filled with aluminum but isn't there a Fel Pro or other manufacturer that impregnates a plate in the gasket. I've used them on big block chevys. Any help?
Old 07-27-2011, 08:54 PM
Pontirag Pontirag is offline
I have found that if you slip a piece of thin stainless steel shim stock between the gasket and the head on both sided it usually last quite a while
Old 07-27-2011, 09:19 PM
71ModelJ's Avatar
Thats the same idea as the Felpro ones for the big block chevys. I was just wondering(cause I can't find it) if Felpro makes them for Pontiacs.
Old 07-27-2011, 09:51 PM
Formulabruce's Avatar
I think that I had some loose ones in a felpro Pontiac kit, just for that. That was a few years ago
" Long may we DRIVE !"
Old 07-28-2011, 09:10 AM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
+1
I had some too, they look just like stainless inserts and they have a little lip so it sits around the hole on the head
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 07-28-2011, 08:02 PM
limejudge69's Avatar
Mr Gasket intake set has the blocking tabs. Part number 502G.
Old 07-29-2011, 05:19 AM
steve25 steve25 is offline
Yes a metal shim will block it off but it does not make for better header tuning if that`s what you are looking for also. The two center ports are still connected to one another and upsetting the Intake flow with unwanted reversion.
This is one of the reasons why Pontiac made these passages smaller with the 5C,6C,6X and 6H castings.
Old 07-29-2011, 06:17 AM
71ModelJ's Avatar
Thank's for the tip
Old 07-29-2011, 10:48 AM
sts sts is offline
Felpro # 1233
Old 07-29-2011, 04:53 PM
tjdjr's Avatar
tjdjr tjdjr is offline
The edelbrock gaskets come with an insert to block x-overs.
Old 07-30-2011, 02:10 PM
brgrenier brgrenier is offline
Does anyone pictures of this?
Old 07-30-2011, 02:27 PM
61-63 61-63 is offline
Google MrGasket 502G or Felpro 1233 and you will get a picture in one more click.
Old 07-30-2011, 04:35 PM
here ya go
Old 07-30-2011, 07:49 PM
Ed Fitzgerald Ed Fitzgerald is offline
Default Blocking heat crossover
I'm in the process of doing a set of 141 heads with aluminum. I think if I was to block the heat crossover with only a stainless shim plate the very least I would do is stuff the area behind the exhaust valves with steel wool in an attempt to push as much exhaust gas into the manifolds as possible. Then in the off chance you didn't like the performance mod you could remove the shim plate and steel wool and carry on. If in fact you liked it you could opt for a more permanent fix. IMO
Old 07-31-2011, 02:26 AM
lust4speed's Avatar
In SoCal we don't miss the manifold heating, but if you drive in colder climates you might want to factor that in. If you only drive the car in fair weather, then blocking the passages and going to an electric choke could be a viable option. Even in warm weather here, the choke has to be locked open or an electric choke conversion installed. Without the manifold heat, it will take 15 minutes or longer for the manifold temperature to warm up enough to pull a normal choke off.
I don't think steel wool would last, but I've read on here about people tightly packing the crossover passages with aluminum foil. I haven't tried it so don't know if it lasts or not. I have poured aluminum and used Resbond with excellent results. Just do a search for Resbond and you should come up with a couple good threads on the matter. If nothing else, separating the exhaust ports sure sweetens the exhaust sound.
Mick Batson
