Old 07-28-2011, 11:51 AM
punisher7's Avatar
punisher7 punisher7 is offline
Default good interior dye
I am looking at dying my interior from poop brown to black. The bench in front has vinyl backing and fabric the rest of the way around. I would prefer to use something I can buy at a local store, but will order vinyl paint and fabric dye if need be.
I am concerned with the dye bleeding as I have never dyed seats before.
Any input would be appreciated! Thanks in advance.
Old 07-28-2011, 12:18 PM
tstevea's Avatar
tstevea tstevea is offline
SEM dye
Old 07-28-2011, 03:14 PM
69gtocv 69gtocv is offline
x 2
Old 07-28-2011, 03:29 PM
pippintook pippintook is offline
I used SEM Dye spray cans too on my 78 TA...was very impressed. I used it for both the velour seats and the console..kick panels...and some other interior trim...has held up pretty nice. If I recall correctly I had to order the SEM Dye from a local store.
Old 07-28-2011, 05:57 PM
punisher7's Avatar
Will the spray cans work on the fabric seats? They aren't all vinyl.
Old 07-28-2011, 06:50 PM
Cammer-6 Cammer-6 is offline
key to good coverage on fabric is to work it in with a old clean toothbrush or something a little bigger.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-28-2011, 07:26 PM
punisher7's Avatar
Sounds good. I'll order some dye and use some nylon brushes.
Old 07-29-2011, 07:07 PM
make sure its a short bristle brush so it gets worked in real good.
Old 07-29-2011, 11:18 PM
6t7goat 6t7goat is offline
SEM dye is the way to go. Use an adheasion promoter on the hard plastic stuff so you get a good bond between the dye and plastic. I just did my 78 TA's original red dash and kick panels with SEM landau black and it looks awsome. You can buy it in spray cans or by the quart and spray it with a mini gun.
Old 08-10-2011, 10:46 PM
sonjaab's Avatar
sonjaab sonjaab is offline
Right here:
http://www.sem.ws/
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala,
94 Buick, 77 Triumph Bonneville
Old 08-12-2011, 12:14 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Did my whole interior with sem. From black to tan, too boot.
Clean clean clean and when you think it's clean, clean it again.
Send it! It’s going home on a trailer.
