Old 08-04-2011, 12:50 PM
punisher7's Avatar
punisher7 punisher7 is offline
Default 6x heads
I have a line on a set of 6x heads for relatively cheap that came off a running 400, are they worth picking up for $100? I don't have a use for them right now, but my understanding is these are good heads. Thanks
Old 08-04-2011, 01:10 PM
rad400 rad400 is offline
Yes worth the $100 do you know if they are 6X4 or 8s the for have smaller ccs than the 8s but the 8s are still a good head too.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 08-04-2011, 01:52 PM
punisher7's Avatar
They have the smaller cc's.
Old 08-04-2011, 02:18 PM
66bonne's Avatar
66bonne 66bonne is offline
Decent price, I'd buy 'em.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 08-04-2011, 02:33 PM
bobunit9's Avatar
bobunit9 bobunit9 is offline
I paid $300 for mine so I would say that's a pretty good deal.
Old 08-04-2011, 02:53 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
YES ! All big Catalina's need a 455 and 6x heads at some point in their history
Then Aluminum heads later.
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 08-04-2011, 03:18 PM
george3171 george3171 is offline
Default 6x heads
will the heads be at norwalk for the races? I would be interested in picking up them if so
thanks george 4403210500
Old 08-04-2011, 03:31 PM
GR8ONE68's Avatar
GR8ONE68 GR8ONE68 is offline
I don't want to start a "you can't run above 9.x on pump gas" argument. But in general, if you happen to be looking in the high 8 to low 9:1 compression ratio, the 4's (with proper milling to dial them in) are good for a 400 and the 8's are good for a 455.
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac
Old 08-04-2011, 04:36 PM
punisher7's Avatar
I'm heading out to look at the heads right now, where on the heads will it say if they are 6x4 or 8?
Old 08-04-2011, 04:43 PM
77 TRASHCAN's Avatar
No arguement from me...:O many here like to live on the dangerous side. I have plans to be dangerous myself...LOL
There's too much good info. on how to build a 10:1 iron head engine, around. Not easy, lots of details. You only live once...
Shut it off
Shut it off
Old 08-04-2011, 04:45 PM
bobunit9's Avatar
There is a boss that will have the number stamped on it.
Old 08-04-2011, 05:40 PM
punisher7's Avatar
They were the #8s. I picked them up, I figure they may come in handy down the road. Thanks for the info everybody.
Old 08-04-2011, 09:39 PM
66bonne's Avatar
You made a good buy.
Jim
Old 08-04-2011, 11:16 PM
punisher7's Avatar
Should I not plan on putting the #8 heads on a 400? I have read that they came on the 400 originally?
Old 08-05-2011, 07:06 AM
Those heads will below compression around 8:1 I think. Good for 87 octane
Conrad
Old 08-05-2011, 05:39 PM
Mr. P-Body Mr. P-Body is offline
As Conrad says, LOW compression, at least for a "performance" application. They'd be good on a "milieage" engine or a "torque" engine not intended for revs and where 87 octane is desired (truck). -8s are "ideal" for a 461 (400 with a 4.25" stroke..). -4s with a bunch milled off, are better for the 400. It has recently been "reported" of chronic head gasket issues with a pair of -8s milled "too far" (.075", and we stay with .060" MAX), on a 400.
Good buy!
Jim
