Old 08-15-2011, 03:24 PM
My72455 My72455 is offline
Default brake lights wont go off in my 72 455
Finally get the motor in my car after 6 months of work and now the brake lights wont go off unless I disconnect the battery. Headlights and turn signals work fine. Called a place and they say grounding issue. Have 1 ground from firewall to RH cylinder head but I dont have one from RH inner fender to frame ground. I havent had one there since I had the car and it worked OK. Should I put that other ground on? Gone over the car several times and can't figure out whats wrong and they're still on! Any suggestions. Thanks Kim
Old 08-15-2011, 03:53 PM
Ron Genovese's Avatar
Ron Genovese Ron Genovese is offline
There is a switch that is triggered by the movement of the brake pedal. you should be able to see it above the pedal (makes contact with the arm). If it is out of adjustment the pedal arm won't engage(reach) the switch to turn off the lights.
66 GTO
Old 08-15-2011, 04:07 PM
tripower's Avatar
tripower tripower is offline
That's what I was thinking. By default, the brake light switch lights the lamps. The brake pedal coming up to it's resting position pushes the switch plunger in, turning off the lights. Try adjusting the switch on top of the brake pedal.
Norm J
