Old 08-23-2011, 02:36 AM
coreybrenner coreybrenner is offline
Default Opinions on reproduction quarters for '63/'64?
http://cgi.ebay.com/ebaymotors/Ponti...item43a8312690
Just wondering if anyone here had bought any of these, and what their impressions were of the product.
Thanks,
--Corey
Old 08-23-2011, 07:12 PM
Ziggy Ziggy is offline
Thumbs down
My suggestion - Don't waste your money. I got these and they do not fit. You can not use them as is. Perhaps you can use sections.
The body contours and slopes/creases are not as the USA "B Body" and the wheel wells are off.
Length is also slightly short for a Catalina and much too short for a Bonneville
Maybe they fit Canadian cars - but, who knows.
You may be able to use the lower rear section - by tilting the body crease line and with alot of adjustments and mods to the wheel well you may make it fit - but, for the cost to do that, it is not worth it to me.
Also, I tried a NOS wheel well molding and it does not align properly - the contour and length are off. Also, the GM fender skirt does not fit in the wheel well either.
I junked the two I bought behind the garage and seeked out an Arizona car and obtained two good rear quarters and saved the frustration.
Old 08-23-2011, 07:38 PM
misterp266's Avatar
Good to know. I considered them figuring I could cut the pieces I needed from them but it sounds like it's a waste of time and money.....
Thanks!
" Darksiders Rule "
Old 08-23-2011, 07:58 PM
Thanks. I guess my first instinct, and the one I acted on as soon as I could, was correct. I nabbed a parts car with solid quarters. :-)
