Old 09-09-2011, 09:41 AM
Nuts an Bolts Nuts an Bolts is offline
Default 1965 421..
Hi everyone... I found off craigslist , this 1965 (421 c.i.d.) #9778791 356HP - Code YJ, 93 heads, When I got to guys garage it was stashed under his work bench coverd in 25yr old oil and dirt and grease ..... I was the first person to take a dirty rag and clean the suffix code YJ and the casting date D-14-5, yet I still didn't know what this motor was.... So I call my Dad and we had quick beer and we pick this engine with in an hour... It was great pickin and having beer with my Pop he's 80yrs..... Can anyone tell me about this motor..... I would post pics , but I don't how to upload from my picture files on my computer to this site , cause when I click the picture icon on this post, a url box pops out! can someone help me !!! thanx Jim
Old 09-09-2011, 10:41 AM
65gto69's Avatar
65gto69 65gto69 is offline
You pretty much have all the info on it, except what car it came out of.
Only things I can tell you from your provided info is that:
"YJ" - Automatic
And normally this engine would have came with #77 heads which are 1965 High performance heads used on 389 blocks in GTO's or 421 HO blocks.
#093 heads were 1966 heads used on 389 blocks in GTO's or 421 HO blocks.
I have heard that late 1965 389 or 421 blocks could have gotten #093 from the factory instead of the #77 heads.
Date code for the heads are located on the outside just below the valve cover mounting pad between exhaust ports. I would think if heads match the block, the head date code should be relatively close to the block date. If the head date code is far into 1966 year than maybe the original #77 heads were replaced at sometime in its life with the #093.
Should have 4 bolt main caps, 4 inch stroke crank, 4.09 bore and 4 bbl carb, and what is called a transfer lug (protruding pyramid cast into the top rear of block) on the passenger side of the distributor pad. You will see it, sticks up about 2 inches. 389's did not have this in that year.
I am sure more people will chime in.
Hope this answers some of your questions.
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 09-09-2011, 11:36 AM
marxjunk marxjunk is offline
65 YJ 356 hp auto tri-power 10.75 comp..77 heads and of course TRI POWER
Old 09-09-2011, 12:49 PM
I looked at the heads again , and found the # 77 on the coner of each side.... Thanx.. Jim
Old 09-09-2011, 12:53 PM
65gto69's Avatar
My bad, YJ is the tri-power motor, must have glimpsed at the YH on the chart.
http://www.ronspontiacpage.com/reference-pages/1965.htm
Mark
Old 09-09-2011, 01:18 PM
email me the pix i will host them for ya..
Old 09-09-2011, 11:23 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
Click on the paper clip which is attachments in the advanced quick reply screen to load pics.
Old 09-10-2011, 12:27 AM
My 66 ...
ID:	256182   Click image for larger version
Old 09-10-2011, 12:29 AM
Thank you ( ITSBACK) ......
Old 09-10-2011, 12:36 AM
Default 1965 421 pics
1965 421 pics
ID:	256184   Click image for larger version
ID:	256185   Click image for larger version
Old 09-10-2011, 01:04 AM
Hot young chick named Maria , she drinking beer and having fun, next my 66 at the Primer Nationals, Ventura Ca..9-3-11
Old 09-10-2011, 01:51 AM
ITSBACK's Avatar
Not sure what I like better, Maria or the car, they both look great. What kind of primer is that?
Old 09-10-2011, 08:07 AM
Default Its a base black with a flat clear...
Its a base black with a flat clear....My 66 before paint...
Old 09-10-2011, 10:01 AM
GT182's Avatar
GT182 GT182 is offline
Nice.... both Maria and the 66.
BTW... what did you do with the Cragars?
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 09-10-2011, 11:10 AM
Still got them with Goodyear Slicks....
