Old 09-11-2011, 10:06 AM
s455d s455d is offline
Default exhaust help needed
I have a 66 GTO 4 speed with a 455 and edelbrock alum heads (6056) round port. I do not want to use headers. Will the repro ram air 4 mans. fit without fitment problems at Z-bar.
Brian
Old 09-11-2011, 11:16 AM
Dick Boneske's Avatar
Yes, any of the '64-'67 A body Ram Air cast iron manifolds fit fine. They give you the choice of 2 1/4" or 2 1/2" pipes. Your setup would probably benefit from an "X" pipe for a few extra HP and a more crisp exhaust sound.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-11-2011, 01:33 PM
Andre's Avatar
Andre Andre is offline
Im not exactly sure. They make the Ram IV round port exhaust manifolds, but I am not sure if they clear the frame of the '64-7 A Body, as that casting is meant to fit 69-70 (68-72 frame)
You should call and ask.
