Old 09-24-2011, 09:17 AM
ERIC AULL ERIC AULL is offline
Default Take a good guess at HP ??
IAII 505 cu. in. 8.9:1 compression, cam= [email protected] Intake262 exhaust274...lift = Intake 608 exhaust 608 w/1.6rockers 112* sep (hyd roller) BDS Supercharger 6 maybe 8 lbs boost. (2) QFT 750 CFM 'blower carbs", e-heads ported by Butler.....what will it make?? Thanks, Eric
Old 09-24-2011, 01:18 PM
Engo's Avatar
Engo Engo is offline
800 maybe?
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven.
https://www.facebook.com/photo.php?f...type=1&theater
Old 09-24-2011, 02:15 PM
Thanks Engo!
Old 09-24-2011, 02:29 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
800 sounds about right with low boost.
Old 09-24-2011, 05:46 PM
aronhk_md aronhk_md is offline
I'd say 800 at the rear wheels will be easy on a mild/safe tune.
Old 09-24-2011, 07:16 PM
Thanks Gents, This will not be raced, just a "driver". I sometimes see guys running 15-20 lbs of boost and say, "WTF"! I guess they are mostly for the track, or someone has a 110 octane still in thier back yard!.......my big problem is gonna be traction....I didn't tub at all (stoopid) so the most meat I can put on the ground is gonna be about 11".............smoke machine!!?? Eric
Old 09-24-2011, 07:30 PM
Yes, a smoke machine Eric.....lol. But you can tub it later if you need to. There are some very fast cars on small tires though these days. Way faster than mine. Nice thing about my turbo is that its zero boost most of the time under regular driving conditions. I could boost to 20 psi if I want though. Low compression, intercooler and methanol/water injection under boost will handle the octane issue. 91+ gas will be sufficient for me.
Old 09-24-2011, 07:45 PM
Thanks Aron, We have 93 octane here (allegedly) at Hess and Sunoco. I would like to run on that if I can..If not I can get some 105 from a "local guy". 6 or 8 lbs. ought to keep me happy.....for a while!
Old 09-25-2011, 12:46 AM
Torment's Avatar
Torment Torment is offline
I showed 760hp at the tire years back with a 462ci, iron heads, 2 old 850's I modded myself and a BDS 8-71 with about 12-13lbs. 8.9:1 and 8lbs will be something to be careful with with pump fuel, unless you're doing some trickery with the cam events or pulling timing... The E's seem to like a bunch of timing in my experience as well - I was up to 34deg before they quit pulling more mph at 12lbs and 8:1. That was versus 25deg with the same tuneup and iron. They should help the pump gas deal though... Gdlk!
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 09-25-2011, 10:41 AM
Torment, We are gonna start at 6 lbs. I am afraid of 'detonation', as we all should be. Thank you for the info, advice, and the GDLK ! Eric
Old 09-25-2011, 10:57 AM
Torment's Avatar
I'd guess about 5% under should put you pretty close on a pump gas deal with a BDS stage 1 or 2 8-71 on a 505ci. Maybe setup pulleys for 5 under/5 over for street and track fun. Gdlk!
Old 09-25-2011, 10:59 AM
Torment's Avatar
Be sure to keep it out of valve float with that hydraulic roller - shift at a reasonable rpm. Blowers, rpm's, and hydraulic lifters aren't the best bed friends...
Old 09-27-2011, 09:00 AM
Torment, I THINK, 8 lbs is 1 to 1 driven...so 6 lbs is underdriven. I am gonna set the rev limiter at 5500 to start......I doubt the car will ever go to the track...Thanks for the good info!! Eric
Old 09-27-2011, 05:22 PM
RA6T7GTO's Avatar
RA6T7GTO RA6T7GTO is offline
Send a message via AIM to RA6T7GTO
Talking
it will make enough power to get you in trouble,cant wait to hear this goat run
1967 RAM AIR GTO 1 OF 156 AUTOMATICS
Old 09-27-2011, 05:26 PM
Silver Judge's Avatar
Jeez, this thing's going to be an animal. You'll need some sticky drag radials on the street and to help you from "GETTING SIDEWAYS......ON THE HIGHWAYS" :
501 HP, 554 ft lbs TQ
Old 09-27-2011, 06:15 PM
Perry, Go terrorize Richie for me! Eric....Thanks S.J. !
Old 09-27-2011, 06:23 PM
RA6T7GTO's Avatar
eric
i think richie is close to being done with the 455, yours is next then my pos.but i will fire him up for you.
Old 09-28-2011, 09:36 AM
Be gentle with him!
Old 09-28-2011, 06:17 PM
ponchopower69's Avatar
ponchopower69 ponchopower69 is offline
If you can get that power to the ground on a 11" tire then you should look at a different suspension set up. They are putting down way more power then that on 275/60 drag radials. Figured Id toss that out there lol.
Sounds like a sweet set up!!
Old 09-29-2011, 10:15 AM
Poncho, Here is a pic of the rear suspension. It was built by http://www.streetrodgarage.com I am hoping for a nice mix of traction/ smoke...just a street car! Thanks, Eric
PS The tires in the pics are "just for rolling" until the build is finished.
ID:	258490   Click image for larger version
ID:	258491   Click image for larger version
ID:	258492   Click image for larger version
