Old 10-06-2011, 11:13 AM
1973Formula 1973Formula is offline
Default What year Shaker Hoods are the same?
Could someone provide info on which years are the same for Trans Ams?
Shakers"
Shaker Hoods?
Front Fenders?
I am more concerned with correct appearance from the outside and not all of the nuances of webbing or small details under the hood.
Thanks,
PS I tried searching, but was unable to find the answers I needed.
1972 Formula 400
Old 10-06-2011, 11:17 AM
SD73's Avatar
SD73 SD73 is offline
Shakers - 70-76 (73-76 mount with a ring clamp to the base).
Shaker Hoods - 70-76
Front Fenders - 70-81
Old 10-06-2011, 11:19 AM
RAFormulas's Avatar
RAFormulas RAFormulas is offline
Externally... the hood and fenders are identical.
70 shaker is slightly thinner on the rear opening edge.
Steve
1970 Formula 400 (YS) M40 (67-Castillian Bronze / 215-Deluxe Medium Saddle)
1970 Formula 400 (WT) M20 (67-Castillian Bronze / 213-Deluxe Dark Brown)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 201-Standard Medium Bright Blue)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 211-Deluxe Medium Bright Blue) *SOLD*
Old 10-07-2011, 08:18 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
70-76 fit the rounder front ends and the 77-81's fit the flat hood models.
SHAKERS:70-76. 70-72 mount with studs to the aircleaner, 73-76 mount with rings like stated.
HOODS:70-76, just bracing that you are not concerned with.
FENDERS:70-81,just bracing and mount differences.
main difference is 77-81 hoods and scoops are a beast of their own. all non turbo hoods are the same as far as i know. there was talk but not sure they confirmed a difference in some later small block chevy 305 engine TA hoods.
there is a 77 early 78 pontiac scoop which is about 3/4 inch shorter in height, a later 78 pontiac scoop, a 403 olds scoop, a 305 chevy scoop.
think that is all, but always willing to learn.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
