Old 10-14-2011, 12:25 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Default Edelbrock 11 Deg Pro Port
Four heads (part no. 77849) arrived a few days ago. We have been looking them over and measuring a few things:
The casting quality appears similar to other Edelbrock products - Excellent
The machining appears of very good quality and is consistent over these four heads with very nice surface finishes
I have not had a 12.6 degree head in my hand yet so I cannot provide any feedback on the similarities or differences.
Seats and guides were in a bag in the box.
Seat outside diameters were much larger than the opening in the head...and thus heads will require machining just to attempt installation of seats. Depth of intake pocket is shown on the pics.
Intake ports as cast at the intake flange are .832” x 1.605”
Exhaust port as cast at the flange are 1.478” x 1.10”
Spring seat diameter is 1.742”
Guide length in the head as cast is 2.100”
Straw is inserted into the oil return passage. Oil return passages are not straight through; some of the passage is drilled from the top and the intersecting passage is drilled at a different angle from the deck side to complete the path.
These bolted very nicely an a block that is here. Location of intake valve opening in relation to bore wall looks very promising.
Intake port outline is a quick scribe from a Butler wideport gasket. Note the outer bolt hole location and the water crossover location compared to the gasket. ???
To me these have great potential…but the bar has been placed very high already with the excellent crop of heads that are out. Time will tell if these are worth the extra effort.
ID:	259956   Click image for larger version
ID:	259957   Click image for larger version
ID:	259958   Click image for larger version
Old 10-14-2011, 12:28 AM
More pics
ID:	259960   Click image for larger version
ID:	259961   Click image for larger version
ID:	259962   Click image for larger version
Old 10-14-2011, 12:36 AM
More pics
Bolted on a Victor intake and carb flange will be positioned .875" higher than the KRE Hi Ports.
ID:	259965   Click image for larger version
ID:	259967   Click image for larger version
ID:	259968   Click image for larger version
Old 10-14-2011, 01:01 AM
More pics
ID:	259970   Click image for larger version
ID:	259971   Click image for larger version
ID:	259972   Click image for larger version
Old 10-14-2011, 02:22 AM
R 70 Judge's Avatar
Wow that is one cool looking head! I can't believe it's that much taller than the Highport heads. Very cool
James
1970 Trans Am
Old 10-14-2011, 05:41 AM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
Default pro ports
well definitly looks like a nice piece to play with.. Keep us informed on work done.
Old 10-14-2011, 09:28 AM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
Thanks for the pictures. Can you get a few more of where the water would enter/exit in the middle of the head?
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
Old 10-14-2011, 10:26 AM
BrandX's Avatar
BrandX BrandX is offline
Are you planning to work one port and when you get it where you want it, having the CNC program done for it, or hand porting
www.MidwestStreetCars.com
Butler Performance
Quillen Motorsports
Don Dial Race Cars
Old 10-14-2011, 11:24 AM
dci dci is offline
Jim that head looks exactly like the casting I have except mine has the 12.5 or.6 degree angle. I have my measurements around here somewhere, but I cannot find them currently. If memory serves me right they are pretty close to what yours are except it looks like the intake port on the 11 degree is raised a little more. Like your self, I laid the port out up higher initially, but unfortunately the casting I have does not have enough material on the port roof to get a good shot at the valve and not break through. We cut the casting I have in half, and you can see inside the water jackets and something I see that I don't like Is the valve spring pockets are very thin. It looks like you could cut them maybe .050 if you needed to. Something else that does not make sense on this head, is why did they put the intake pushrod holes in. Those should be left out. Don't you think???? Nice pic's and good info.
Don Johnston
DCI MOTORSPORTS INC.
330-628-3354 cell
330-850-5050 shop
Designer of the Tiger Heads and the NEW DCI Ram Air V heads !!
Old 10-14-2011, 01:44 PM
cgeise's Avatar
cgeise cgeise is offline
Its my understanding you can get them with ou the push rod holes -- I am surprised the intake flange does not go up clear to the v/c rail - hmmm
Old 10-14-2011, 03:09 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Great Jim, thanks for the pics
So will the extra 1.035" on the intake flange add to an already fairly long intake tract with a std victor bolted up ?
Do you see this as an issue in some combo's ?
Working on going faster (and now staying dry at the same time !!)
Old 10-14-2011, 04:19 PM
LMSRACER's Avatar
LMSRACER LMSRACER is offline
Default Comedy Interjection !!!
Everyone,
I don't know about anyone else that ports heads and intakes, but my hands/joints and wrists are beginning to ache just looking at those heads. Jim R., don't forget to stock up on the pain reliever of your choosing before getting started.
Larry S.
Old 10-14-2011, 06:56 PM
BrandX,
I plan to port one of each and send to CNC...but that might change depending on tracing and machining costs.
Don J,
I am a bit concerned with the available bowl depth. Would like a peek at that cut up head you have. :-)
Don W,
Yes the intake length will be a bit longer in these compared to others. Trend seems to be higher RPM and shorter overall intake runners.
Larry,
I will be stocking up on aggressive grinding burrs to assist in relieving these heads of lots of aluminum.
Old 10-15-2011, 03:16 PM
Forgot to mention these are intake pushrod delete. They do not have pushrod "holes" for either, instead they have pushrod slots. A machining pass has been made through the slot for both intake and exhaust.
Water hole pic is attached also.
ID:	260149   Click image for larger version
ID:	260150   Click image for larger version
Old 10-15-2011, 06:36 PM
mgarblik mgarblik is offline
Don, on the head that you cut open, is there any water near that push rod slot? On the Old Edelbrocks, we broke through numerous times trying to make room for some decent sized push rods. They were very difficult to repair in there too. With the center water passage, I was concerned in that area.
Old 10-17-2011, 11:11 AM
dci dci is offline
mgarblik, we cut the head in half and I cannot really tell. Looking up through the water holes in the deck, it appears there is water there.
Jim after looking more closely at your pic's and comparing measurements. It appears that the only thing different about the intake side is that Edelbrock drilled the intake manifold bolt holes up higher. If that is the case, when you start porting you may blow through the roof.
I just got a new computer and I have not figured out how to load photo's yet or I would have already posted pic's myself.
Don Johnston
330-628-3354 cell
330-850-5050 shop
Old 10-25-2011, 12:58 AM
Port mold of the as-cast intake port. The diameter under the seat is 1.75"
ID:	261088   Click image for larger version
Old 10-26-2011, 01:12 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Kool Stuff...
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 11-05-2011, 08:00 PM
Some progress on roughing these in.
ID:	262342   Click image for larger version
ID:	262343   Click image for larger version
Old 11-05-2011, 08:19 PM
T Syron's Avatar
T Syron T Syron is offline
Jim,
Are you going to keep it an oval port or is that just the way your roughing it in.
Keep up the hard work, you're an asset to the Pontiac performance community.
Tom
