After owning my 69 for over 32 years I am ready to convert to disc brakes. Researched the forum and did not find good answers about which kits work with 14 x 7 rally II wheels. I want the install to go smooth with no mods and I am not wanting to hunt for different wheels. Anyone have good luck with there project?
TODD |
I have 70 GTO spindles and calipers on mine and have no problems running a 14x7 Rally II with a 235-60-14 on the front. The spindles and calipers are the same for a 69 F-body and 69-72 A-body.
Good luck Last edited by boater bill; 11-06-2011 at 10:00 AM. |
Todd, it's all about the caliper bracket. If you use a GM caliper bracket, you'll be able to run 14" wheels. If you go aftermarket, that bracket will rub inside the wheel. I've done it on a 68 Camaro. That is I machined the spindle's top bolt boss .615" for it to become a disc brake spindle, installed GM back plates (you can buy repro, they cost next to nothing but are kind of thin), installed used GM caliper brackets, bought calipers and rotors and 72 Monte Carlo brake hoses (Yes, 72 Monte Carlo)at the local auto parts store. I bought a booster/MC/proportionning valve from inlinetube.com.
Thanks for the info. Looks like I need to start hunting for GM brake parts.
TODD |
I also want to switch to disc. Would front rotors and calipers work off a 73 El camino?
68 firebird 400 hardtop 68 gto convertible auto a/c pw (project) 68 gto hardtop 4spd (project) 69 firebird convertible 350/auto 72 formula 400 4sp lucerne blue a/c (project) |
No, it will work all the way to 72. 73 and up is a different animal.
