Old 11-06-2011, 11:49 AM
sd455hota's Avatar
sd455hota sd455hota is offline
Default Olds block #s
Where are the stamped #s (vin and engine code) on a 79 Olds 403 block? Thanks
Old 11-06-2011, 10:31 PM
GStage1's Avatar
GStage1 GStage1 is offline
Visit www.442.com and check the FAQ section...should be on the deck next to #1 cylinder.....just below where the deck surface on a casting protrusion.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 11-07-2011, 10:40 AM
sd455hota's Avatar
Great, Thank you very much.
Old 11-14-2011, 11:26 PM
Grand73Am Grand73Am is offline
Steve F.
Old 11-15-2011, 12:56 PM
speedrider's Avatar
speedrider speedrider is offline
Originally Posted by Grand73Am View Post
I sanded that tab the best I can for now. It seems my number is upside down from the picture you are showing of yours. Is this possible, or is something not right? I tried to take a picture, but every one is blurry. I got a piece of crap camera.
Old 11-15-2011, 01:08 PM
I have 2 403's and they're both right side up. But I don't see that it matters if it's upside down as long as you can read it to be able to tell if matches your VIN.
Steve F.
Old 11-15-2011, 02:16 PM
speedrider's Avatar
I sanded it so I can read it and the number stamped is 52954. The last 4 numbers of my vin are 9791, so I guess this is not the original engine that came with my car. Would that be correct? And thanks for the responses.
Old 11-15-2011, 07:35 PM
Correct. It must not be the original engine to the car.
Are you sure it's a 403?
Steve F.
Old 11-15-2011, 07:51 PM
speedrider's Avatar
I am definitely sure it's a 403. It has the tell tail oil filler cap just forward of the breather cover. And the 4A heads.
Old 11-15-2011, 08:11 PM
Okay the 4A heads are a clue to the 403. The oil filler isn't, since that's on any Olds engine.
If you get under the engine and look up at the side of the block, there are large 403 numbers cast onto the block, which is the most obvious way to tell .
Steve F.
