Old 11-09-2011, 06:37 PM
cressy cressy is offline
Default 1981 4 speed transmission
Are the 1981 aluminum case 4 speed trannys Muncie or Borg Warners and are they the same as a Z28 except for bellhousing?
Old 11-09-2011, 07:56 PM
bs78ta's Avatar
bs78ta bs78ta is offline
Borg Warner and yes same except bellhousing
Butch
Old 11-09-2011, 10:08 PM
OK Thanks.
Old 11-10-2011, 04:44 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
depending what motor they were behind, you can find some crazy ratios. i have 2 that are 3.42 first gear, 1 an alum case and 1 a steel case, both from 305 chevy 81 TA's.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 11-12-2011, 08:14 PM
pontiacmonstr pontiacmonstr is offline
Thumbs up
i had one from an 80 z28, it had 4 rings on the input shaft. no idea what gears it had, but 1st was crazy low with a 3.73 gear in the rear. you could start out in third with little trouble. that tranny didn't last but 1 summer. sure miss that thing, it sure was fun!
