THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Worst engine ever made thread
I'll start the list with the Vega 4 cylinder aluminum POS
The Detroit 8.2 diesel V8 is an honorable (dishonorable ?) mention for trucks.
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
Northstar
https://www.flickr.com/photos/197745168@N07/ "There's nothing more unsatisfying than watching an electric car go down the dragstrip." |
How bout the v6 chrysler that tend to sludge up with around 40,000 miles? I think it's a 2.7 litre. the 4-6-8 caddy was a peach too.
6.0 ford diesel
Cadillac Diesel or the 8-6-4 form the eighties.
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
Vega
Chrysler 2.7 V6 GM / Olds Quad 4 / Quad OHC GM / Olds 5.7 V8 Diesel GM / Olds 4.3 V8 Diesel Northstar Caddy V8-6-4 Caddy 4100 V8 PowerJoke 6.0 PowerJoke 6.4 Damn near anything Mitsubishi Ford 90* 3.8 / 4.2 V6 That's a start . . .
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
It was a 5.7 olds diesel and was patterned roughly from a 350 olds gas engine, I had one in a 81 bonneville and also worked at a Buick dealer as a line mechanic at the time and seemed to get all the warranty work on the diesels that came in. That engine was a gutless wonder, but if it was taken care of properly it would last. Mine had 150,000 miles on it when I pulled it out and sold the engine. The guy I sold the car to wouldn't buy it unless I converted it to gas so I put a 350 olds cutlass motor in it to sell. I put the engine in the local paper and had 11 calls on it the first day. I sold it to the first caller. GM also speced the I/P that Standyne built and insisted on an aluminum pump even though Standyne recommended steel sleeves inside the pump on wear areas so the pumps didn't last too long. The typical "save a penny now spend $200 later GM syndrome". The main problem was neglect from the owners and the local service station didn't know how to properly service them and as a result the breathers plugged up and created excessive crankcase pressure and blew the front and rear seals and took the rings out too. The engines would start burning and leaking oil and a good many were run low for oil and blown up. There were 2 of us mechanics at the Buick dealership that drove diesels, I had my 81 Bonneville and my friend had a 79 Toranado that we put a ton of miles on without any problems. Kinda like the corvair and the Fiero, the olds diesel was killed just when they got it perfected and running well. Typical GM problems with field testing cars after the sale instead of before.
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated Last edited by Sirrotica; 11-15-2011 at 06:10 PM. |
Chrysler 2.2 with the death rattle and junk carburetors. They got a little better when they added fuel injection.
Cadillac 4.1 V8. They were bad with or without the 4-6-8 system. GM 1.8 OHC 4 cylinder. Rattling, oil leaking, oil burning junk! GM 3.3 V6. Never idled smooth even when they were new.
If it ain't broke, fix it 'till it is |
The Olds 4.3 V6 diesel was supposed to be a gem, but try finding one.
The Caddy V8-6-4 was actually a iron block and heads 6.0L (368") V8 version of the old caddy 472/500/425. Basic engine was bulletproof, the V8-6-4 system killed it though. The caddy 4.1 was an aluminum block / iron cylinder headed 125HP POS. Oil drainback passages in the cylinder heads were measured in the thousandths of an inch, and stopped up at will. I will NEVER forget how much of a whore it was to replace the coolant thermostat, much less install a set of accessory belts! Can you imagine - Caddy installed those fine 125HP turds in 4500+ lb RWD DeVilles for a few years? I know - my Mom had one. It topped out at about 85, after a three-mile runup! What a laugh!
I almost forgot about the 2.5 iron puke after 1980 and before the tech 4 in 1988. I think the alloy that GM used in the block was silly putty........................
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated Last edited by Sirrotica; 11-15-2011 at 06:31 PM. |
I was surprised to notice on a friend of mines Duramax Duallys Diesel engine that it has a tag that says it was manufactured by Mitsubishi? WTH
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
It's manufactured by General Motors. Isuzu is a partner, but is now a minority owner. http://www.dieselpowermag.com/featur...ine/index.html Maybe the turbo is a Mitsu piece? I dunno?
POS 4cyl in the old Renault Le Cars!!
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
Hate to admit I ever owned one......1982 Citation....that 4 banger engine was junk! I believe it was an Olds engine though???
I did a changeover to a 350 cutlass in an 84 RWD cutlass that had a 4.3 diesel in it and the engine ran fine just couldn't keep a fan belt on it. I also had no problem selling that engine either.
You would have thought taking a V6 out that was based on the V8 out and putting a gas V8 in would be pretty simple, not so I could have put a 302 ford in it just as easy. Nothing interchanged or fit, many many runs to the junkyard to find all the parts to install that engine. |
We'd source a complete 307 4V Olds with trans and swap 'em out. Back then we didn't worry about catalytic converters, gas tank fill restrictors or fuel evap systems like we'd have to now. Pulled a BUNCH of POS Olds 260 2V gas engines, V6 and V8 diesels and made 307 cars out of 'em. Ran GREAT when we were done!
Hey - no problemo bud!
By the same token in a well taken care of Pontiac 400 with over 100,000 miles on it there is just a carbon ridge and usually less than 2-3 thousandths wear on the cylinders. |
