Old 11-27-2011, 11:46 AM
ycis ycis is offline
Default new 64 catalina owner here
My black friday included picking up a 64 catalina 389 convertible from Turkey Rod run here in florida.
only issue is with the alternator/voltage regulator. gone through 2 alternators (autozone) and none are producing any power at the post...pretty much leaves it to the reg.
nowhere locally carries the regulator listed for the car, (including napa/autozone/discount auto/orielly/etc).
is there another more common car that uses perhaps a more common regulator? different year bonneville gto perhaps? or hell is there a more common internally regulated alternator thatll bolt in?
Thanks in advance, looking forward to gleaning this forums knowledge on old pontiacs! first one ive ever owned!
Old 11-27-2011, 12:16 PM
Andre's Avatar
Andre Andre is offline
Congratulations on your purchase. If you are anywhere near the Hobe Sound area, drop me a email at [email protected]. I have a few spare regulators on the shelf. It's a fairly standard piece for GM cars 64-? Camaro, chevelle impala etc.
PS- please post pictures of the car. I'm sure everyone will want to see what it looks like
Andre'
Old 11-27-2011, 12:18 PM
I wish as it sucks to not be able to drive the car missing a 20 dollar freaking part, im up here in Jax.
had napa order what I believe is the correct 3 post regulator (one on the car is a 4 post, and based on comments in another thread is simply the wrong regulator for it)...its clearly a very new part...im guessing the previous owner replaced it recently and just put the wrong one on.
pic from rod run attached, will get more/better later!
Old 11-27-2011, 12:39 PM
on a side note...anyone know the difference between the bwd r153 and the bwd r159 regulators?
all the local parts stores list both as "compatible", but of course the one that appears to be correct (159) is not available while the 153 part is available locally.
physically they look identical based on the pics on the advanceauto website...anyone ever use the bwd r153 model successfully?
Old 11-27-2011, 12:59 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Check on E-Bay to see if you can find a solid state. There is a guy who sells them sometimes & lists all the applications. I was searching my year and Pontiac and they came up, but have not looked for a while.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 11-27-2011, 01:48 PM
Stuart's Avatar
Stuart Stuart is offline
Auto zone part number VR716, but it appears to be special order
NAPA part number ECH VR140, it shows they have them in the local warehouse here
Oreilly's part number R281, available within one day.
However, just what is the car doing or not doing? I assume it's not charging? This is cut and pasted from another forum since it's quicker than typing:
All of the old alternator systems work the same way, when you put battery voltage to the field the alternator will put out full output-this can be 16+ volts. when you disconnect the battery from the field the alternator will put out 0 volts. voltage can be varied by how fast the points cycle in the regulator. the actual figure you are looking for with a CHARGED BATTERY is 13.8-14.2 volts. with a low battery the voltage will be considerably higher, right after start the voltage will be higher, the voltage is regulated by the the voltage input by the voltage regulator and the time differential of open/closed points between the battery and field.
there are 2 common failure modes on a mechanical regulator
1-a break in the fine armature wire that controlls the points, this will result in 0 charge.
2-pitted points in the regulator, this usually results in the points sticking and you will get a 16+ volt charge, or just erratic readings.
checking for a bad regulator, you do that indirectly:
1-fully charge the battery and hook a voltmeter to it, it should read 12.5-12.8 volts.
2- start the car and look at the voltage on the voltmeter, it should read 13.8-14.2 volts.
3-if it reads around 16, replace the voltage regulator.
4-if it reads 12, unplug the regulator and jump from the battery to the field terminal on the regulator.
A-if the voltage jumps to around 16 replace the voltage regulator.
B-if the voltage stay at 12 replace the voltage regulator and alternator (you could just replace the voltage regulator but if the regulator was allowing the alternator to charge at 16 V and it burned out it will damage the new regulator.
these are just the rules for mechanical regulators and have no correlations to todays charging systems.
Old 11-27-2011, 01:50 PM
stevep's Avatar
stevep stevep is offline
The regulator fits 1963-1968 big Pontiacs. It should only have 3 terminals on it.
If your regulator has 4 terminals on it, it won't work.
You may want to install a 1 wire alternator! That will solve your problem.
Old 11-27-2011, 02:55 PM
Yes its a 4 post vr installed currently. No charge at alternatorwith engine running other than battery voltage...and no change with rpm.
Is there an internally regulated alternator avail that's a direct fit/swap?
Old 11-27-2011, 04:17 PM
sorry, was typing earlier on my phone.
the overall situation...
car starts and runs fine...battery tests fine (under load)....it just does not charge at all.
troubleshooting done
1. replaced alternator
2. tested voltage with car running and off at battery: both identical (12.8-12.9)
3. tested voltage at alternator post: reads same as battery regardless of rpm
4. removed positive from battery when running, car dies
5. unplugged VR with car running, no change...also reads 12.8-12.9 at input into VR
and also confirmed this is a 4post (shiny cover) voltage regulator which has been mentioned in this thread, and another..and via pm...that this particular one wont work on the car.
i fully expect to get the proper 3 post VR in from napa tuesday...and hope thatll be the end of that!
one question I do have, is that even with the 4post VR on the car now, only 2 wires are used....which posts do those go on on the 3post VR...and shoudl I be using all 3? (ok I guess thats 2 questions)
took a few more pics for you...ill wait till I get it all detailed and out of the garage for some better shots.
ID:	265073   Click image for larger version
ID:	265074   Click image for larger version
Old 11-27-2011, 05:04 PM
stevep's Avatar
The regulator only uses 2 wires. Is your connector still in place?
You should be able to find a 1 wire alternator @ a local starter/alternator rebuilder, but I'll bet that once you have the correct regulator, you should be fine.
Old 11-27-2011, 05:12 PM
Yes...connector is in place for the 4 post style....wire using the bottom and 2nd from top connector currently....nothing in top or 3rd post of 4post style. Vr is mounted so posts are facing drivers side fender
Old 11-27-2011, 05:20 PM
stevep's Avatar
Default Yup!
I just looked @ my 64 Bonneville and that is exactly how the VR is wired.
Old 11-27-2011, 05:56 PM
ok and im assuming yours is a 3 post that just uses the same plug as the 4post VR?
well thatll be easy as pie...looking forward to tuesday!
Old 11-27-2011, 06:11 PM
stevep's Avatar
Yes, you are correct.
Old 11-27-2011, 11:11 PM
Engine-Ear's Avatar
Welcome to the PY forums!
Nice convertible!
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 11-28-2011, 09:05 AM
Hitman's Avatar
Hitman Hitman is offline
I saw that car down there. They had it moved to the back so you must have jumped on it quick.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 11-28-2011, 09:53 AM
Was completely at the end of the day....I had given up my search and was walking back to the tow vehilce parking behind stadium when I saw it.....just got lucky I guess
Old 11-28-2011, 12:01 PM
wfbarto's Avatar
wfbarto wfbarto is offline
Stuart, I take it that the part numbers you list are for mechanical regulators and not solid state units? Thanks.
1966 Bonneville Convertible, 421, 4spd. (in progress)
1966 Bonneville 4 Dr. Hdtp. (survivor)
1999 Trans Am Hatchback, red, 6 spd.
Old 11-28-2011, 03:41 PM
quick question about front and rear springs.
im pretty sure the rears are shot, and the front is way too high given the rims/tires on the car at the moment.
Id like to replace all 4 as well as the shocks, but id like to keep the current rear height, and lower the front about 2" or so.
im guessing from the looks of the rear springs, they arent new =)...and given the flex in the rear suspension when you put a passenger or two in the back...they are in dire need of replacement.
im afraid of replacing with new will jack the rear of the car up, and i dont want that...searching for moog springs for a catalina brings up about 9 million different parts on ebay and the like.
Anyone know solidly a moog or eibach spring part number that will result in lowering the front and rear say 2 inches from stock?
Rear shocks also look useless and original, seraching on that comes up with a different suggestion for perhaps every different sort of shock manufacturer in existence....so ill ask my fellow catalina owners who have perhaps already gone this route!
Thanks in advance!
Old 11-28-2011, 03:45 PM
stevep's Avatar
Go to www.espo.com. You can get their phone # from there. Call them, they will make you what you want for a decent price.
