Old 12-01-2011, 09:20 AM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Default Need a Q Jet for a 350
FINALLY changing over my 70 Le Mans to a 4 bbl. 350/4 sp/3.08. Going with stock 11 heads, slight port, screw in studs, cut .020-.030. Likey going with a Melling SPC-7 068 equivalent cam with Rhoads lifters. Daily driver with a little more, not a race car.
Probably just run down to Advance to get a rebuilt stock unit, I imagine any 70 400 application would work? Numbers matching not an issue.
Old 12-01-2011, 09:52 AM
F ROCK's Avatar
F ROCK F ROCK is offline
neat! tell us how it runs!
Old 12-01-2011, 11:35 AM
77 TRASHCAN's Avatar
Not knowing what your budget is.....
A parts store is alleged to be the worst place to buy a crab. A reman carb can be a hodge podge of parts thrown together. You could be buying a genuine headache w/ no way of making it work correctly.
Call Cliff, and see if he's possibly got something on the shelf, or look on e-bay for a new carb, if possible....
A friend gave me a Q-Jet, I was overjoyed, until I de-crudded it, and found the reman sticker on it.....
Shut it off
Shut it off
Old 12-01-2011, 07:57 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
i had a parts store rebuilder once, never again what a nightmare. couldn't get the car to run right. bought a new spread bore holley with an electric choke, about 10 minutes of external adjustments and it runs great. on a stock 400 by the way.
if you have to have a Q-jet, imo, find a good core and put a kit in it yourself or i bet rich at M&R engines could hook you up.
Old 12-01-2011, 09:20 PM
Massee is building the combo. It should be fum. WIll likely need a bit more gear and an overdrive box....Soon.
Old 12-02-2011, 03:35 AM
pontiac 455ho's Avatar
pontiac 455ho pontiac 455ho is offline
Send a message via Yahoo to pontiac 455ho
yes the reman carbs are the worst. i had 3 of them not one of them workt right. so i got a good core from cliff . had him seal the bowl plugs and recolor it. and bought all the parts from him. runs great even when cold no bog. and not bad mpg cliff is the best at q jets. and i love the look when pepole see im ruinng a qjet.
Old 12-02-2011, 08:33 AM
70UglyBird 70UglyBird is offline
I have a rebuilt carb from a 74 Firebird 455 I'd sale for 115 + shipping. I bought it from another member here on PY and I didn't end up using it. There are some pics if you search on my user name.
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges
1973 Formula 4spd long term project
