Old 12-01-2011, 08:36 PM
grandville455's Avatar
grandville455 grandville455 is offline
Question BOP Composite dist gear
I was wondering can a guy drill out his .491 gear to .500 fairly easy if he has a drill press? Either that or does someone have a .500 gear they would like to trade? Mine is in excellent shape!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 12-01-2011, 08:41 PM
66bonne's Avatar
66bonne 66bonne is offline
Darby-P-Dude drilled mine out; no big deal.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 12-01-2011, 09:19 PM
Sun Tuned Sun Tuned is offline
Reamer would be best, but sure you could do it. Just a little plastic fantastic.
MSD ???
Old 12-01-2011, 10:16 PM
Thanks, Jim Good to hear it can be done easily
Bob, The more I have thought about this i really like the new pertronix dist PNX-D120710
, Looks like a solid piece, and since my car is set up to run a pertronix anyway it just makes sense to go that route, plus they have a proprietary way to limit the advance whatever that may be kinda like MSD I am guessing just different?
something like this Bob?
http://www.tools-plus.com/irwin-11214.html
2995A74 mcmaster carr
Darby
Old 12-01-2011, 11:44 PM
Nah, lets just keep it simple.
If your nervous about it go buy a brand new drill bit , a nice new sharp one, and....
Drill baby drill.
A sharp bit will do that just fine. Like butter.
Old 12-02-2011, 03:50 AM
goathead455 goathead455 is offline
I drilled mine with a new bit and a hand drill,no drill press and it worked fine.
Old 12-02-2011, 08:05 AM
Drill baby drill.
Thanks Bob, Not nervous was just wondering if it could be done without ruining it,lol..this is pretty straight easy just drill, not like setting the angle up when i did my metering blocks on my dom ,lol that took some adjustments
Darby
Old 12-02-2011, 08:55 AM
Lookit these things are like 100.00. I have no qualms about telling you I've driven in no telling how many roll pins in the last 15- 20 years. And I have no problem telling you guys my arse draws up tight enough to drive a 20 penny nail into it every time I put one on. Just makes ME nervous. They are a good piece and I have no issues recommending them over a bronze gear.
I do have one reservation about it though. I'm a worrier, I admit it. So take this for what its worth. The thing about a 1/2 inch bit is that I think when you get done that the hole will be slightly larger than .500 even if only by a couple thousands of an inch especially doing it by hand I would think. When you get done you don't want it to wobble on the shaft because if it does It will do same inservice and that we don't want. Would eventually make a nice wear pattern on gear from oscillating around some.
I haven't tried it on one of these gears, but I think I'd buy a drill bit just under .500 whatever it would be, as I'm not in my shop, might be a letter or a number drill. Get as close to .500 without going to .500 and then take some penetrating oil or even some 3 IN 1 oil and swab a brake cylinder hone in and outta there till you hone it out to desired slip fit.
I've done it with my hone on lower bushings and it fits fine. I believe if it were me, that would be what I'd do. You really dont want that gear rocking on that shaft, as far as long term reliability goes.
I know , I know I worry about too much. Let the laughing begin.
Old 12-02-2011, 09:02 AM
Bob, that is the exact way I was thinking also with the .500 bit being to big to begin with, I do have a hand reamer bit not sure if it goes to .500 tho, But I agree I do not want any rocking!! I do have a letter drill bit kit too. I may just trade someone that has the bigger one and not worry, then we both sleep good at night! ,lol
Darby
Old 12-02-2011, 09:15 AM
Man dont sweat it I know you got a brake cyl hone and that will work just fine. Just be there a few more minutes thats all.
I'm just concerned drilling it right off with a 1/2 drill bit will leave it a bit floppy.
Fix the one you got it'll be less stress.
Mail it to me, I'll fix it for ya on the house.
Old 12-02-2011, 09:29 AM
Send ya the gear u mean Bob? The msd box is wired for the pertronix, Just plug it in and go, no rewiring for the HEI, msd etc so either way, thats what i am running wether it be a new dist or i use my old points one, just like the features of the new is all. Only thing I am not sure on is where their vac starts etc
Darby
Old 12-02-2011, 10:11 AM
Ollie's Avatar
Ollie Ollie is offline
grandville455
No. don't use a taper reamer.
you need to use a straight flute straight shank,
like this.
http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=945782
Its ok to giggle and snicker, Dont laugh and point
Old 12-02-2011, 11:34 AM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
This is exactly correct. A straight reamer is the way to do this. (Carbide if possible) Best way is in a lathe with the reamer in the tailstock. If you know someone at a machine shop this would be a 5 minute deal for them.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 12-02-2011, 01:51 PM
Wade,
I do know someone at a shop, so just use a straight .500 one then? Or go smaller first?
Darby
Old 12-02-2011, 03:51 PM
superdutybob's Avatar
superdutybob superdutybob is offline
I was a machinist in a former life. You're only talking about removing .009" total which is less than normally allowed to go from a drilling to a reamer. I would chuck it up in a small lathe and indicate it in so it's running true. Feed the .500 reamer in and it will be perfect. I wouldn't hesitate for 1 second to do it this way.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 12-02-2011, 06:27 PM
That is correct, We use a 4.998 but a .500 should work fine.
Wade Congdon
BOP Engineering
