Old 12-19-2011, 04:09 AM
3goats's Avatar
3goats 3goats is offline
Default 69 nos wheel wells gto
Does any body have a set of nos gm wheel wells for a 69 gto that were bought as replacements from gm. Are they different from the originals?
Did gm make one set fits all like 68 to 70?
Reason is the set I have for my project have date codes of A 28 2 which I think is 1972.
It has a circle cut out line for heater box on pas side and slightly different or shorter metal at splash area at bottom. Otherwise identical.
Any thoughts ? Thanks
Old 12-19-2011, 05:23 PM
gto4evr gto4evr is offline
wells are the same 68/69 and then a different well 70-72 -- they're not interchangeable across the 69/70 threshold
I'm not sure the date codes read that way on the body panels, I thought no one was ever able to decifer the fender date stamps (of which that number reminds me of) but the blower motor cutout template pressed into the fender you describe means it's a 70-72 well. Does it have holes for J nuts to hold it to the fenders or square cutouts where you'd put one of those license plate plastic retainers? The 68/69 has square holes for those and the 70-72 had the round holes for the J nuts.
Old 12-19-2011, 05:29 PM
68RamII's Avatar
68RamII 68RamII is offline
3Goats,
I just had two NOS pieces for a 68 that would not fit my fender or quarter panel. That is probably why they didn't make it on a car.
John R. Zerucha
1968 GTO RA II Convertible
Sorry..The race car is Buick Powered
70 Skylark @2800 lbs
8.78 @ 153 mph 535 Stage 4 2850 lbs
8.97 @ 149 mph 523 Stage 4
9.36 @ 143 mph 464 Stage 2
9.77 @ 135 mph 464 Stage 1
88 Hawk @2355 lbs
8.06 @ 167 mph 535 Stage 4
7.90 @ 171 mph 572 Stage 4
Old 12-20-2011, 01:18 AM
3goats's Avatar
I'll check those holes. Thanks for the info guys
Old 12-20-2011, 12:11 PM
It's worth noting that in 69 there are two different style inner fenders, its at the lower rear where they seem to have lengthened the metal to negate the need for the rubber skirt.
I'm not sure if it's an early - late thing or a plant thing.
Old 12-21-2011, 02:02 AM
3goats's Avatar
I checked the wheel well holes today and they are square holes the same size as the other 69's I have. I took pics of them and will post them shortly.
North
Interesting to know that there were different styles. Didn't know that.
These ones seem to be shorter at the rear and at the front as you describe not longer?
The creases in the metal on the curves are a dead match to all others that I compared them with also. Which had to be the same stamp machine I would think? But they are slightly different as you described?
Old 12-21-2011, 07:09 AM
The difference is significant, the long ones have a good 1.5 to 2" of extra material at the back where they meet the bottom of the firewall. This extra material replaces the rubber flap that most 69's have there. I first ran into it replacing a tub that had been cut for access to the AC blower. We pulled a set off a 69 lemans from California and they were the longer ones.
Old 12-22-2011, 03:43 PM
3goats's Avatar
Default pics
Front splash area on driver side is shorter? See img. 295 and 296.for front splash area.
The rear splash areas are slightly different in img. 294.
ID:	267887   Click image for larger version
ID:	267888   Click image for larger version
ID:	267889   Click image for larger version
Old 12-27-2011, 02:09 PM
3goats's Avatar
Are these maybe for a 69 grand prix?
I heard somewhere that the GP's will fit a 69 GTO, I dunno.
Maybe I should fix the old ones as i'm running out of time.
Old 12-28-2011, 04:39 PM
GP units look like they will fit from the engine side but the wheel opening contour is completely different.
