Old 12-23-2011, 12:49 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Default What would cause this????
Any idea's???
Calvin Hill
Hill Performance / Mondello Tech Center
708-250-7420
Old 12-23-2011, 01:08 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Dropped before installation and took a while for engine vibrations to knock the piece out?
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 12-23-2011, 01:24 PM
russ467's Avatar
russ467 russ467 is offline
Squirrels?
70 Formula
Old engine:
467 HO headed
6.79 1/8th mile @ 101.87 no N20. 1.44 60ft
6.23 1/8th @ 111.83 w/nitrous
1.37 60ft
New Engine
IAII 535
Calvin Hill Eheads
Few test passes made. Tore it up. Just got it fixed.
Old 12-23-2011, 01:30 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Nitrous explosion
First Pontiac powered street car in the 7's
[email protected]. 3460#s
Old 12-23-2011, 01:39 PM
Region Warrior's Avatar
No damage to anything else?
Hit with a ratchet handle.
Old 12-23-2011, 01:56 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Had a very similar thing happen in the 80's (man I am getting old). It was an Accel cap. Never found out what caused it, never saw it again until now. I just chalked it up to a manufacturing flaw that showed up after vibrating on the engine.
Old 12-23-2011, 02:03 PM
cgeise's Avatar
cgeise cgeise is offline
My CSI skills say it happened al at once - hense the clean break all around. Did the engine ever get a lot of fuel in the grank case ? the fumes could hace gotten up there and the touched off by the spark ?
Old 12-23-2011, 02:06 PM
60man's Avatar
60man 60man is offline
Did ya get mad at it Calvin...?...
Merry Christmas bud...
ECM member.
MANDRA
Old 12-23-2011, 02:36 PM
mgarblik mgarblik is offline
I have seen a few caps break like that but it was usually in a street application and a non-vented cap with spring clips, like a Mopar. In those cases it was fuel vapor making it's way into the dist. from a super rich condition or a non-working PCV. If it was not struck and broken as mentioned, I would check crankcase ventilation. I usually drill several vent holes in all my race caps to prevent this and any ozone build-up.
Old 12-23-2011, 05:28 PM
Half-Inch Stud's Avatar
Had an HEI rotor "explode" and take the cap out. Lucky it was in the garage.
Old 12-23-2011, 05:46 PM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
Poor job of checking rotor phasing!! Merry Christmas Calvin!!!
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
I'd vote for a bad rotor here too!
Old 12-23-2011, 06:53 PM
Hooter's Avatar
Hooter Hooter is offline
Operator error........
67 Bonneville ragtop
Old 12-23-2011, 07:42 PM
Sun Tuned Sun Tuned is offline
Automatic self venting cap.
Old 12-23-2011, 07:59 PM
67 ProTouring Catalina's Avatar
67 ProTouring Catalina 67 ProTouring Catalina is offline
Originally Posted by 65nss4spdGTO View Post
Any idea's???
Calvin Hill
708-250-7420
how bout smacking it with a hammer cause your pissed the car is not running right ? happened to me before
Old 12-23-2011, 08:19 PM
Chupa's Avatar
Chupa Chupa is offline
bad motor mounts!
Happened to me... Although your failure looks different...
Old 12-23-2011, 08:30 PM
pontsd pontsd is offline
Sure case of driver abuse..... No doubt about it!!!!
Calvin, you can't make it go faster that way , I already told you I did not think inproving air speed in the cap would help.. LoL.
Old 12-23-2011, 09:32 PM
Calvin Hill
708-250-7420
Old 12-23-2011, 09:55 PM
I get it now. It's intentional. It's for rotor Phasing.
Old 12-23-2011, 10:12 PM
Hooter's Avatar
Inside joke with Calvin and I. Gotta know the owner. Definitely not done intentionally.
