Old 12-26-2011, 10:08 PM
ArticGTO ArticGTO is offline
Question Carburetor advise for 1970 400ci
Anyone have some advise on Carburetor for my goat?
Just had motor bored .020 with new pistons, new lifters, rebuilt heads roller rockers, re-balanced with new ring gear and harmonic balancer, and higher duration cam.
I am using stock intake with I beleive has spread bore.
Trying to figure out if I need an adapter plate if I use a Holley 0-80450 - Holley Model 4160. Has anyone used this carb? Would the carb fit on stock intake without an adapter plate? Would I have a performance issue if I used just a square hole plate or should I find an adapter plate to match the circle holes in stock intake? I don't have the stock Rochester carb.part #7040264.
Want to make a driver car but want to have power when I need it.
Old 12-26-2011, 10:27 PM
carbking's Avatar
carbking carbking is offline
The 80450 is listed as a 600 CFM square bore carburetor. This should break down as approximately 300 primary, 300 secondary.
The stock 7040264 is normally thought of as a 750 CFM spreadbore carburetor. This breaks down as approximately 150 primary, 600 secondary.
By using the stock manifold (150/600) with the square bore carb (300/300) you can figure basically the smaller of the two figures for both primary and secondary. You now have approximately 150 primary plus 300 secondary, or a 450 CFM carburetor/manifold combination.
Using the recommended Holley adapter will return some of the CFM, but causes the air/fuel mixture to make extra turns which an air/fuel mixture really doesn't like to do.
If you like Holleys, by all means use one; BUT change to the proper manifold. Personally, I think the 600 is a bit small for your combination. A 750 would be a better choice (again, change the manifold).
I would suggest you would be money and performance ahead by any of the following:
(A) acquiring the proper Q-Jet (spread-bore)
(B) having Cliff build a different Q-jet specific to your application
(C) using a Carter TQ aftermarket spread-bore (my personal choice)
Jon.
Old 12-28-2011, 01:01 AM
Thanks for your advice!!
Looking into a Q-jet as we speak so I can go back close to original!!
I really am not impressed with aluminum intake!!
I like the stock stuff!!
Old 12-28-2011, 02:42 AM
cuz68's Avatar
cuz68 cuz68 is offline
Question
Jon.
Jon i did not know that carter made new spread-bores, What is the cost of them? and where can you find them? Are they bolt on and ready to go? Thank you Randy.
Old 12-28-2011, 09:40 PM
carbking's Avatar
Randy - Carter made in previous years part numbers 9800 without EGR port and 9810 with EGR port and cap. Both are 800 CFM with GM linkage and electric choke. A little looking should find a vendor that has them.
Jon.
