Old 12-29-2011, 02:43 AM
gmil60 gmil60 is offline
Default 61 Pontiac 389 Crankshaft Change
Dear Members,
I'm in the process of rebuilding my 61 Bonnevilles 389. During the rebuild I want to change the rotating asymbly to make it a 421. The car has a Hydramatic transmission and I am having a problem locating a forged aftermarket crankshaft with the bolt circle and size that will accept the Taurus coupler ring /gearless flexplate. I want to keep the Hydramatic transmission so the adapter plate to use a later automatic is a direction I don't want to take. I would appreciate you help.
Sincerely Gmil60
Old 12-29-2011, 11:03 AM
hellerods's Avatar
hellerods hellerods is offline
Why do you need a forged crankshaft for a cubic inch upgrade? A stock cast crank will work fine except for a race-only engine.
Old 12-29-2011, 01:17 PM
Default 389 crankshaft change
You are right for my street application I don't need a steel crank. I decided to upgrade the lower end when I had it apart. I received a build proposal from Butller which gave me the idea to change out the lower end and upgrade the cylinder heads. If I can't find a aftermarket crank to work I will probably use a cast 421 crank. I spoke with Buttler performance, I'm in the process of sending my flex plate to their shop so they can match up a crankshaft and check the spacing.
Sincerely Gmil60
Old 12-30-2011, 04:18 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by gmil60 View Post
... bolt circle and size that will accept the Taurus coupler ring /gearless flexplate...
Every single Pontiac V8 '55 - '81 used the same crank flange bolt pattern.
I'm guessing you were trying to say "torus cover" (see 'torus' in any dictionary); but your [mis]spelling gave me quite a chuckle!
Old 12-30-2011, 08:01 AM
Being this is my first Pontiac, I did not realize the bolt circle on the rear crankshaft flange was the same. The majority of the rotating parts I am ordering through Butler due to their experience with Pontiac Engines. The actual question arose when I got ready to order the forged aftermarket crankshaft. I was asked by Butler to check the bolt circle and spacing of the flex plat and it did not match anything they had in inventory to send me. I can only assume companies like Scat seem to be making crankshafts mostly for late Pontiac engines.
Oh!! by the way I'm glad I gave you a chuckle with my spelling of Torus. I never knew anything like a fluid or hydraulic couplers existed before the purchase of this car. Thanks for your input
Regards gmil60
Old 12-30-2011, 11:10 AM
Pontirag Pontirag is offline
[QUOTE=pontiac jack;4506674]Every single Pontiac V8 '55 - '81 used the same crank flange bolt pattern.
QUOTE]
Jack are you sure on this? I thought there was a change in the late 50's
Old 12-31-2011, 01:33 AM
Safari Larry's Avatar
Safari Larry Safari Larry is offline
The crank flange bolt pattern did not change in the late 50's. What did change was counterbalancing material was added to the flange which prevented bolting up a 55/56 dual range without removing a little material on either the flange or the flywheel. It is only a problem with the dual range. That was discussed here some time ago and is discussed at this link.
Larry Gorden
POCI 1956 Tech Adviser
www.PontiacSafari.com
