Old 01-03-2012, 09:56 PM
jusjay's Avatar
jusjay jusjay is offline
Default pulley setup with electric waterpump
Hi, what are using for pulley steups when you have a ele waterpump? My 64 has the alt and PS pump on the drivers side and the alt belt runs straight through the ele motor on the pump?
Old 01-08-2012, 04:40 AM
Formulabruce's Avatar
have used a serpentine set up with an Idler.( march set up) Either way you will want and adjustable idler.
not that much, or no adj on some PS pumps..
Here is a article with pics from HPP may give you some ideas..
http://www.highperformancepontiac.co...tem/index.html
" Long may we DRIVE !"
Old 01-08-2012, 12:52 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
I used Spotts' alternator relocation kit to move it to the passenger side and it worked for me. Never thought of the serpentine set-up but this was a cheap fix that worked
Old 01-08-2012, 02:15 PM
jusjay's Avatar
Thanks guys, that helps alot!!
