Old 01-17-2012, 08:59 AM
lugnutt's Avatar
lugnutt lugnutt is offline
Send a message via MSN to lugnutt
Default Tin Indian Performance Alternator Mount
Has anyone had experience using this mounting bracket. I have it installed and it seems like it is pretty flimsy. I don't have alot of confidence in it. It looks nice, it just looks like it needs another bracket to support the back of it.
I've tried to call Tin Indian to see if they left something out. Tried a few times, left message and no return call.
Name:	pontiac 455 (3).jpg
If its one thing I know, its..... Uhhh I forgot .
What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!!
Old 01-17-2012, 09:58 AM
ERIC AULL ERIC AULL is offline
Try sending an e-mail....works better with Kevin.....Eric
Old 01-17-2012, 10:18 AM
PaulatFast PaulatFast is offline
Maybe you could find the company that actually designed it and see what they say. Of course I'm just assuming he stole the design from someone else.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 01-17-2012, 10:39 AM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
Ouch!
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 01-17-2012, 11:10 AM
60man's Avatar
60man 60man is offline
My solution..Have since went to 16v and no alternator
Not sure whose mount it is....
Name:	alt mount brace (Small).jpg
ECM member.
MANDRA
Old 01-17-2012, 11:39 AM
70 lucerne lemans's Avatar
70 lucerne lemans 70 lucerne lemans is offline
I've had one for a couple years and it works fine.It does flex slightly under load,but it holds the belts on.You might want to helicoil the two bolt holes,they take a lot of load.
Mark
1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD....
1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs
(1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor
[email protected] on 150 shot
Old 01-17-2012, 04:18 PM
jm455ho's Avatar
jm455ho jm455ho is offline
I have something similar. Seems flimsy to me as well, but has been working fine so far.
www.hobracing.com
Old 01-17-2012, 04:41 PM
GTOGEORGE's Avatar
Looks like a normal Alternator mount to me.
George
Old 01-17-2012, 05:19 PM
Tom Vaught's Avatar
Boost Engineer
The Butler Performance Alternator Relocation kit parts are a lot better design.
See Article with photo of parts.
http://www.highperformancepontiac.co...e/viewall.html
Driver's side kit would be PN TRP-ALT1 and costs $85.00
I know the Pontiac guy who makes the Kits for Butler and it is a well designed/ quality part.
Tom Vaught
Old 01-17-2012, 05:36 PM
Big Injun's Avatar
Big Injun Big Injun is offline
Here is a link to MMS & Accesories who I believe is the original manufacturer. Scroll down to the bottom. http://www.mmsacc-stainless.com/html/engine_access.htm
I think BOP was also selling the product.
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 01-17-2012, 06:16 PM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
Mark from BOP designed that bracket in 1999 as an alternator kit for the BOP belt drive. I remember it well as I was there. It has been a very good bracket for many years and was just strong enough to eliminate most flex. It was then copied by several vendors a number of years later but the mounting was changed from holes to a slot for additional mounting positions. This weakened the bracket allowing it to flex too much and allow belt throwing and slippage. The design shown on the mms site in Dave's post is an exact copy of the BOP bracket albeit $9 more expensive. In fact, the picture shown on an engine was taken by us (BOP) at Norwalk and we used it for years. It was clearly lifted from our site. Our current bracket PAK46 is made from stainless steel and is supplied with coated grade 8 bolts. Thank you for supporting BOP...
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 01-17-2012, 06:33 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Hey Paul at FAST, you just made my Christmas list next year!.....Cliff
Old 01-17-2012, 07:45 PM
Tom Vaught's Avatar
Boost Engineer
Like I said, The Butler design is better. Doesn't surprise me the individual would copy the poor design.
As Wade said, You can have a great design but after a few copy the part with "their improvements" you go from a properly designed part to a piece of crap.
Sorry, but you do not have a robust part, Lugnutt. I would recommend that you get either the Butler part or the ORIGINAL design part from the BOP people.
Tom Vaught
Old 01-17-2012, 08:52 PM
DINO1's Avatar
DINO1 DINO1 is offline
Default Bracket
Here is a picture of mine, I belive it is the Butler original.
Name:	100_0531 (Medium).jpg
Old 01-17-2012, 09:09 PM
Ron H's Avatar
Ron H Ron H is offline
My BOP looks just like the one Dino has. I did have to go to deep pulleys from RARE to stop throwing the belt at launch with 5400 stall. But I think the deep pulleys should be SOP when launching any higher than 3000 rpm.
68 Firebird
Are you running with the wind or breaking it?
Old 01-17-2012, 09:14 PM
hopper146's Avatar
hopper146 hopper146 is offline
I'm pretty happy with the e-bay special i picked up....just need a stronger mount for the back of my power steering pump now,,,,,always something....
72 G.T.O. 455HO Auto
69 Firebird 400 Conv. Auto. IAII 540 and damn vroomy....
Old 01-17-2012, 09:44 PM
Hooter's Avatar
Hooter Hooter is offline
Been running the BOP one for years. Works great.
Wade(or anyone else) - I'm putting a 16V Powermaster alternator(smaller than stock) on my race car this winter. Looks like the mounting tab circumference is a little smaller. You guys sell a kit for these or am I making my own?
67 Bonneville ragtop
Old 01-17-2012, 10:32 PM
BLANK1's Avatar
BLANK1 BLANK1 is offline
CVFRacing has some nice looking brackets.
http://www.cvfracing.com/pontiac-brackets-s/64.htm
Old 01-18-2012, 09:45 AM
Rob B's Avatar
Rob B Rob B is offline
If your talking about the RARE aluminum pulley for the crankshaft, I agree 10,000%. Anybody racing or running some decent HP should NOT be using the stock lower pulley. If you are, it will fail!
I had a stock steel pulley break off back in 05 at VMP about the 1000' mark. Did some nice damage to the hood and fender. looked like someone took a plasma cutter to it. They flex like a
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 01-18-2012, 12:31 PM
60man's Avatar
Let me know what you come up with Brad. I MAY go to a 16v alternator later ??? Seems like most guys with 16v don't bother with one. I have 3 passes and didn't charge 16v battery so far.....and ran coolling system in staging lanes just to test it out....
ECM member.
MANDRA
