Old 01-22-2012, 08:43 AM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Default Ford Engine help 1970 Cougar
Have a chance at a 70 Cougar XR7, looked at it a while ago and passed because of a rod knock in the engine, which was a 302, so I was told. Had the 302 callout on the air cleaner as well. Now the car has to move and I got a call back.
I think it should have a 351 in it, not sure which version.
Anyone out there that knows Ford info that I can PM to decide what to do about the car?
Anyone have a 70 351 sitting around? WHat should a used engine cost, and how much to rebuild one should I find a core engine?
What else should I look at with this car?
I figure to fix it then sell it, the taillights are the only reason I'd buy it in the first place!
Old 01-22-2012, 09:33 AM
stevep's Avatar
stevep stevep is offline
I believe that the 302 was the standard engine in 1970.
If you can decode the data tag on the door, it should tell you what it came with.
Do the sequential tail lights actually work?
VIN code G is a 289
VIN code H could be a 351 Cleveland or a Windsor!
Old 01-22-2012, 10:00 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Std. engine was the H code 351W 2 bbl. Opt. was the M code 351C 4 bbl. The M code was std. on the Cougar Eliminator. Opt. on the eliminator was the G code 302.
The others are the 428 and 429.
Old 01-22-2012, 10:04 AM
PunchT37's Avatar
The 351W looks like a 289/302 with a taller deck, thus wider than a 302. To the untrained eye, a 351W looks like a 302.
The 351C has canted valve heads. It will look like a "big block" 351.
Old 01-22-2012, 10:23 AM
If it's a toasted 302 what should I get for the car, Windsor or Cleveland? Cleveland that much better or can you make the Windsors run well enough? If cost is about the same I'll go for the Cleveland?
What's a 351M? Is that a small block 400 cube engine? Does that fit on the same trans as the rest? Seems they are around in trucks, are they worth building?
IF you got a pretty nice car with a trashed nonoriginal engine what would you do?
(Besides put a Pontiac 455 in it....)
DO they make clutch pedal conversions for these cars?
Old 01-22-2012, 10:42 AM
PunchT37's Avatar
I`d prolly go W. The parts avalibility for the w`s are light years ahead of the c`s. The c`s are harder to find as they were discontinued in 1973. I CAN find you a 351C down here if you want.
The 302/351W and the 351C use the "small block" bell housing pattern. The 351M/400 use the big block pattern. I would NOT go with a M or a 400.
Both the C and the W can be made to run very well. You`ll be on your own more on the C as not as many are out there now, and many out there that have one that runs well, don`t want to give out their parts list or tuning tips.
Old 01-22-2012, 10:43 AM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
A well built 302 would be nice in that car. Just rebuild it to Eliminator specs for a 69-70 and have a ball with it.
Try calling CRUSHPROOF! 512-386-9889
Old 01-22-2012, 11:02 AM
Boss 302 or regular 302?
Old 01-22-2012, 11:38 AM
gregneun gregneun is offline
Default 1970 XR7
Kieth,
I like them and would recomend getting it if the price is right. Not a family car, or even as teenagers, getting into the back seat was a chore and cramped.
The Old Car Manual Project http://www.oldcarbrochures.com/new/1.../dirindex.html
has the brochure. It shows that the 302 was na for the XR7. They could have put anything in there though.
Good luck and keep us posted,
Greg
Old 01-22-2012, 01:54 PM
SRR's Avatar
SRR SRR is offline
Would be worth more if you can repair the 302. Not to mention cheaper and easier in the long run. Interchangeability will be a nightmare if you decide on a different engine.
― Calvin Coolidge
Old 01-22-2012, 02:36 PM
PunchT37's Avatar
Looks like the only 302 in those cars was the Boss 302. It might have had a regular 302 installed at some time. It`s prolly a 351W.
Old 01-22-2012, 03:20 PM
Windsor would be my choice.the 69 and 70 units have desireable heads. they get better milage than the clevelands and are more responsive on the low end. IMO the 302 is a boat anchor.
Cougars are cool cars, specially with a 4 spd.
If it's cheap buy it and enjoy it.
former." --Albert Einstein
- Winston Churchill
Old 01-22-2012, 04:55 PM
sleepy's Avatar
sleepy sleepy is offline
That would be an awesome sleeper If you can find a 429 thunderjet to put in it.
Why is he not suspended?
Old 01-22-2012, 08:21 PM
MYstery solved... IT's a 68 not a 70....
Went to check out the car today, vin and tags code out to 302 2V which is in the car. So it is the original engine, with the rod knock.
SOme torque box rust but not horrible, some bubbling of the paint job, car was changed from green to black. It is an original xr7 C4, 3.00:1 axle. Nice interior, nice vinyl top, crank windows, am radio tach and funky switches on the dash, all stock. Wire wheel covers. In the end nothing special. 99k miles. New exhaust and alternator, tires OK, brakes done recently.
So what do I budget for a stock 302 rebuild??? And torque box replacement? Looks like minimal bubbling of paint but it is a Ford so I do expect some mud is in the car.
SOOOOOOO............what's it worth???
Old 01-22-2012, 08:26 PM
stevep's Avatar
Mustangs Unlimited should have the torque boxes.
Glaser's Mustang Barn in PA is probably better for you.
Old 01-22-2012, 08:47 PM
1k-3500.00 depending on condition.
I'd seriously think about a 351W. just for giggles
- Winston Churchill
Old 01-22-2012, 09:11 PM
stevep's Avatar
How much is it??
Old 01-22-2012, 09:42 PM
buds56's Avatar
buds56 buds56 is offline
I saw a 68 available here in va missing the motor, good body,bad paint, complete interior for $1400.
A fellow I know of bought one a year ago that ran good had a fair amount of bondo in the quarters ,but looked ok for $2500.
Old 01-22-2012, 11:38 PM
$3000. seems a bit high unless you really know your way around them and can buld an engine yourself. So it's over $5k to get on the road, then some rust repair for a pretty low option base engine car. WHo knows what that will run, a grand maybe for the torque boxes and then whatever else it needs with bubbling paint.
IF anyone else is interested I'll give you the number.
Old 01-23-2012, 01:41 AM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
First gen (67-68) Cougars are pretty nice, like classy Mustangs with sequential taillights. I had a new 4spd one in 67. You don't see that many of them, I prefer the '67s because they have a cleaner look (didn't have the side marker lights on them) and you see more surviving '68s. $3k seems like a lot for a '68 that needs everything. I should have shown you the Ford engine I have in the shop when you were there.
