Old 01-24-2012, 10:59 PM
BlackBird68's Avatar
BlackBird68 BlackBird68 is offline
Default what do you think a '68 block & 6x-8 heads cost?
I have a '68 GTO block (not HO), I believe YS code and I had it cleaned, baked, and magnafluxed. It is also zero decked.
I also had the heads done as well. They were machined a bit.
Anyway, I am thinking of going a different direction and was also thinking of just unloading what I have so far. How much is reasonable for the block and heads?
Old 01-25-2012, 11:59 AM
MescaBug's Avatar
MescaBug MescaBug is offline
If its bare (no parts, no valvetrain), I would say around 500$ for both if you're lucky. Nothing fancy here.
Old 01-25-2012, 11:38 PM
well here is the thing, I bought the car and had the engine taken apart and cleaned and everything.
It had Ross racing pistons, a roller cam, stock rods, stock crank...and I have all of those parts but I doubt the pistons are worth anything because the skirt had some chewing and what not.
Last I heard the cam is good and so is the crank.
