What is correct cylinder head casting 1970 Ram III automatic
The 70 Judge I'm working on has no. 13 cylinder
head castings. If I'm reading my GTOAA ID book correctly it is supposed to have no.12's. Is that right? It is a Ram III automatic trans non air Judge. |
i believe ra engines got 12s regardless of transmission.
12's, every original. I've examined.
12's
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#12's.
12's
12's
Paul FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first. My site... needs updated- www.fastrestorations.com 68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs! |
Actually...
I would investigate further. Not to dispute anyone...but if the date codes fit...well...stranger things have happened at Pontiac...especially when the car involved is an automatic. Anyone recall the DOCUMENTED '69 RA III T/A auto/air car in Cali with "62" casting heads on it? I fought with the GTOAA for years after they tried to deduct 10 points off of my 50k mile original '69 auto because they swore it should have "16"s on it. Finally got thru to them when a 29k mile original auto car pulled in with "62" castings...documented original car also. My car took 1st in Restored class that year. I had to do a nationwide survey via "The Legend" and found ZERO documented '69s delivered with "16"s. Just sayin'...not entirely out of the question that your's are correct...and I would DEFINATELY find out for sure before initiating any action to "fix" it. In any event...prepare yourself for the controversy. Not to coin a phrase...but some folks just "can't handle the truth!" JMHO. Ron
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
Have never ever ran across original '69 production dated & installed 16 big valve D-ports. Have had a bunch of them. Have easily looked at several hundred original '69 YS's, XH's, XF's, all had their 62's. Many of us would argue 16's were a typo in Pete's book.
I'll leave this with these statements: 13's have always been 20 times easier to come up with than 12's, esp if one needed a pair of 12's to date a TransAm (late J of '69 & later dated 12's). It's amazing how the 78-80cc chamber 13's magically make it on to the "born with numbers matching" 70 400 RAIII engines. Puppy mill "restorers" cutting corners couldn't have anything to do with that
OPH, i believe big valve #16īs were used only on early 1969 Firebird RAIII w/AT, code YW.
At least MPC suggests so and they do exist: |
Also, the #12 casting # indicates 66.27cc combustion chambers, stronger valvesprings and no oil sheilds due to the stronger valve springs.
No RamAir heads uses oil shields on the valve springs. These are the 1970 RAIII w/MT and AT, heads, also used on 400 w/MT. #13 heads has 75.70cc combustion chambers uses "standard" strength valvesprings w/oil shields. These heads were used on 350hp 400 w/AT only. |
Thanks for all the responses.......It sounds like these heads
are not the originals.....We'll probably leave the 13's on it for now since it isn't going to a point judged meet in the near future. The owner does Multi-make shows, where the casting numbers on the heads would be irrelevant. I can understand why a previous owner would have bought the wrong heads, as it plainly states in the GTO restoration guide in the engine section that all automatic cars had 13's in 1970.......however if you flip over to the chapter on Ram Air engines, it states that the Ram Air III used no. 12 cylinder heads. I was initially fooled by the first passage in the book myself, but found no. 12's listed under the Ram Air chapter after everyone on the forum said that 12's should have been used. Thanks again to everyone for their help and input. |
Would also love to see quite a few original low mile uncut #12's cc'ed. The last set of virgin #12's I had had gone through for a '70 YZ engine I owned we cc'ed 4 chambers, & all were in the 71cc range. Also carefully cc'ed several pair of relatively low mile 13's in the early to mid 90's, & every pair had came in between 78 & 80 cc, no sunken valves, nice cores.
The MPC's are not gospel and have been proven incorrect on many occasions...
I've owned two RAIII T400 cars myself and both had 12s.
I've also owned three different WT 400/350hp 4spd cars with 12s. Only saw the 13s on YS engines in T400 GTOs or on T400 Grand Prixs. |
We might as well pick up the debate around heads 62/48.
Chamber cc on 62?(large valve) Chamber cc on 48? Some say 72cc some say 75-80cc. Anyone have TRUTH here? and NO GUESSING!! Hard to believe that #13 had smaller cc than #62 when the compression began to drop in 1970. Only difference between 48/62 was use of different valvesprings Man vs Auto? |
I have found the "eyebrows" in combustion chambers being smaller in #48 and #12 heads than the eyebrows in 1968-69 #16, 1969 #62 and 1970 #13.
Just like the eyebrows in 6X-4 350 heads are smaller than 6x-8? It´s quite easy to see, by the naked eye, that the chambers of the #48´s and #12´s are smaller. This may indicate that also #12´s initially were aimed for the 1970 350H.O. that never came into production because of low interest? Just like the #48 350H.O. heads ended up on the 1969 RAIII/400-428w/MT, due to slow sales of the 350H.O.? #13 heads chambers would be slightly larger than #62´s due to the compression drop 1970? At least the lenght of valves, being shorter in the #13 heads, indicates this. |
Could be the 350 HO and the OHC 6 didn`t sell well enough so they were both dropped for `70. |
Interesting topic, does anybody have the specs of the various valve springs used by the factory?
69 Pontiac Firebird 400 convertible - project 69 Pontiac GTO 400 - sold 70 Buick Skylark 350 custom - project 72 Pontiac GTO 455 - sold |
