Old 02-03-2012, 12:22 PM
estokes-bonnie66's Avatar
estokes-bonnie66 estokes-bonnie66 is offline
Default 14" 57 rims to 15" 55-56 rim with poverty caps
Folks,
My recent purchase, a 1957 Pontiac 4-door/3-bench wagon, is going to need new tires. I would like to change to 15 inch rims and keep the small dog dish hub caps. Can I simply get some earlier rims that were 15 inch? My clips on the 14 inch rims are in good shape and the hub cap patina matches the rest of the car.
Simply?
Ed S
1957 wagon
1966 convertible
Old 02-04-2012, 10:43 AM
Safari Larry's Avatar
Safari Larry Safari Larry is offline
Congratulations on your recent purchase, the 3-seat Chieftain wagons seem to be relatively rare. Production total was 11,536.
Yes, you can use earlier 15 in. Pontiac rims. It's good that you have the clips, they are more difficult to find than the rims.
Larry Gorden
POCI 1956 Tech Adviser
www.PontiacSafari.com
The Following User Says Thank You to Safari Larry For This Useful Post:
Old 05-08-2024, 09:01 PM
Rustytinman55's Avatar
Rustytinman55 Rustytinman55 is offline
Default 56 Chieftain 2dr wagon.
What's everyone thoughts
about putting my 14inch cragers with 225/70 coker ovals .
Old 05-09-2024, 12:58 AM
blueghoast's Avatar
I like it.
GT
Old 05-09-2024, 01:21 PM
If the wheels clear the drums you still may not even get the wheel/tire combo to go into the rear wheel well without a lot of trouble. You will at least have to deflate the tire every time you install/remove it. Maybe even disconnect the shocks.
Old 05-09-2024, 05:12 PM
Default TIRES ON THE 56 WAGON
My cragers with my coker rwls
fit easily. Not sure about anyone else but I think it's bad ass now . Time for some glass packs.
Old 05-09-2024, 08:21 PM
Default Dual 4barrel 317 intake
Folks I have a dual 4 barrel intake manifold that came with the wagon . I am looking for the correct carbs to mount on it .
The intake part number is
#32-960. The mounting bolt holes are 4.25 x 5.5 " .Not sure what carbs I can find to mount on it. Looking for info . The motor is original 317. Currently with a 2 barrel. Looking for emails or text to me please .
Thanks Dave
Thanks Dave
ID:	633494   Click image for larger version
Old 05-09-2024, 10:12 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
If you click on
https://www.pontiacsafari.com/L1Earl...Quad/index.htm
you will end up on Larry Gorden's web site info on that manifold.
