Old 02-13-2012, 11:20 AM
mechanic17 mechanic17 is offline
Default diesel/one-ton truck owners--advice needed
I'm seriously considering buying a used type I or III ambulance soon for a camper conversion. Mid-late 90s vintage is about what I can afford. The most common seems to be the ford f350/450 chassis with a 7.3 TD powerstroke. There are some Dodge 5.9 TD Cummins out there, and a few GMCs.
I do intend to load the thing up with my junk, but won't be towing a big boat or anything, so I'm more interested in powertrain reliability/economy than ultimate power, and I don't forsee modifying it.
I'm sold on a diesel for the mileage and reliability--problem is I know nothing about them. Never owned one. I read a lot of tranny replacement stories. SO, given that I'm starting from square-one, can anyone give their recommendation for best combo?
I'm assuming that any heavy chassis by the big three will do, but if someone wants to warn me about weak frames, rear-ends, electrical issues, consider me a welcoming blank slate. I do plan on buying down south to avoid something rusty underneath. Thanks in advance.
Old 02-13-2012, 02:43 PM
David Holmberg's Avatar
The 7.3 Ford is probably the way to go. Excellent motor and reliability, good chassis to work with as well. The only weak point is the E4OD transmission, but once rebuilt (100K miles) it should be good to go.
You don't want a 90's GM diesel, they're ok, but not in the league with the PowerStroke.
Old 02-13-2012, 07:21 PM
74gtoguy 74gtoguy is offline
Default diesel
a 95-98 12 valve cummins is the way 2 go. better mileage than a ford, less problems.
i have one for 15 years and 280k miles. trans was replaced at 270k
avoid the powerstroke to many problems!!
Old 02-13-2012, 08:01 PM
mechanickeith's Avatar
Both are good as stated. You will pay a premium for the Cummins. 7.3 mechanical engine fords are lower power than the electronic ones but are bullit proof. If you get a Cummins, get a manual trans one.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 02-13-2012, 08:58 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
You're very wrong if you mean the 7.3 P -Stroke.
Cummins had some bad blocks that would crack and
they had that dreaded dowel pin that would drop and cause problems.
Seen plenty of 7.3 P- Strokes (and Cummins) surpass 500K. 280K is nothin'.
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
Old 02-13-2012, 09:38 PM
password taken password taken is offline
Go down to a local diesel shop and ask them, they will tell ya!!! Ive worked on tons of these trucks and will only suggest you buy a cummins.
67 lemans convertible
400/4sp
Old 02-13-2012, 09:39 PM
Default cummins
never any bad cummins 5.9 blocks, the dowel pin is a minor problem easy and cheap to fix before it happens
cummins have easily done a million miles with only valve adjustments and pms
Old 02-13-2012, 10:04 PM
The Boss's Avatar
The Boss The Boss is offline
Just speaking from my own experience, my 97 F-350 7.3 spun the guts of it's automatic transmission at 74,000 miles and then promptly ate it's 3rd cam position sensor. My 2000 F-350 7.3 is still pushing hard on it's original automatic transmission with 214,000 miles and has only munched one cam position sensor - about 1000 miles ago.
I can tell you I ask a lot from my trucks and they have NEVER let me down. I have pulled many a lumber truck out of the mud (including a cummins powered boom truck) and have given several cement & tri-axle dump trucks the extra umph they needed to get out of each of their predicaments.
Although I'm no longer looking to test my current transmission I'm sure if needed it would be up to the task.
And go racin' in the street.
Old 02-13-2012, 10:18 PM
Seems damn near every auto behind any diesel pickup is junk, 'cept the D-Maxx
Certain years had cracking issues (the blocks cast in Brazil I believe)
http://www.locknstitch.com/1999_to_2...lock_crack.htm
We put one in a nice Dodge that cracked out of the blue for no reason, owner didn't abuse it.
I worked on a 6.9 IDI that had a pushrod go through the rocker arm just a few hundred
miles short of a 1,000,000 miles.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 02-14-2012, 12:29 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
The 6.2-6.5 Detroit Diesels (1982-1997 GM) are perfectly fine engines for driving around and towing, but don't expect to do any redneck modifications to belch black smoke or win races. The TH400 behind them is bulletproof unless someone was stupid about maintenance, the TH700-4R\4L60E is something I am not comfortable running due to how many I hear about needing to be rebuilt, and the 4L80E that came in some after 1991 is the one to have.
If you can afford it, the 7.3 is also a very nice engine. I've never been a Dodge fan, so I don't know too much about the Cummins.
Old 02-14-2012, 01:07 AM
Is there any auto trans (stock) that came behind either the Powerstroke OR the Cummins that can be trusted? Remember, we're talking '90s vintage.
BTW, I am working my way through the other diesel threads and have read the "tow vehicle" one twice already.
Old 02-14-2012, 10:37 AM
Sirrotica's Avatar
I agree, the 6.5 turbo in my 93 K3500 has close to 230,000 miles and the 4L80E is just a T400 with an OD electrically shifted. The engine and the transmission both work fine in my truck.
One other thing about the 6.5 is parts are usually much cheaper and many sources of used parts are available.
That being said I also have a IH with the N/A 7.3 in it that is about the same mileage as the 6.5. Both of mine are mechanically injected so the parts in the injection systems are relatively cheap and easy to work on. They all have advantages and disadvantages, most important thing is how the former owners maintained them, they'll all run good with proper maintenance.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 02-14-2012, 01:13 PM
Hmm, I'll look more into the GMC option--I'm taking my time, trying to get educated.
I see that the Freightliner medium duties give you a Cummins AND an Allison tranny--though I don't see many in my price range without 300k on 'em. Anybody have any experience with something like those?
Old 02-14-2012, 10:18 PM
Would you consider the Dodge Sprinter?
Old 02-14-2012, 11:44 PM
Ben M.'s Avatar
This is ultimately the biggest point. Unless it's a Ford 6.0 or an Olds 5.7, there really is very little in the way of terrible problems if they've been maintained and taken care of. And if they haven't you can take care of that and improve it to get them back into service.
Old 02-15-2012, 12:39 AM
6.9 & 7.3 IDI's are common and you can buy em for about the same price as a 6.2 GM from those years (usually pretty cheap)
However, a 6.2 will beat a 6.9 IDI on fuel economy easily.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 02-15-2012, 12:49 AM
Ben M.'s Avatar
Depends on where you live. Where I live, the 6.2 is rare but goes for peanuts. The 7.3 is more common, but the also costs a few grand more just because it's the 7.3. The 6.9 is a bit cheaper, but most of those trucks of that era have had the snot beat out of them.
Old 02-15-2012, 10:12 AM
Sirrotica's Avatar
Look here for GM diesel information, I got a ton of information on my 6.5 turbo on these forums: http://www.dieselplace.com/forum/?
BTW, I paid $1800 for my Ext cab K3500 dually 4X4 so the chevy /GMC can be bought pretty reasonably. Needed some TLC but it does everything I need in a truck, haul, plow, and it surely ain't pretty but I don't need a pretty truck.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 02-15-2012, 11:15 AM
V-Ped V-Ped is offline
I have a 6.5 TD/4L80E truck that has 180k on the clock. It has been very reliable for me...once I learned about the PMD problem. the Pump Mounted Driver is a pair of high current transistors that control the electronic fuel injection pump. When it starts to go, the truck will stall repeatedly or not run at all. The trouble codes indicate thet the injector pump need to be replaced which is very high dollar and that solves the problem because the PMD is replaced at the same time. However, with the help of forums on these trucks, you learn to only replace the PMD and relocate it to a cooler place. Relatively cheap and easy to do. My favorite forum for these is http://www.sixfiveturbodiesel.com/ .
I frequently haul an overhead camper and tow a boat or cars some distance without issues. The truck just loves to pull stuff at about 65 mph. Go faster and mileage drops off. I do alot of trailing with friends, sometimes involving 80 to 100 vehicles. Some of these guys nicknamed my truck "The Savior" because it doesn't fail and freqently is required to help them along.
This is the same engine/tranny in huge numbers of H1's serving in Iraq/Afganistan, hauling around the heft of up-armor. That indicates a relatively good track record and provides huge stockpiles of spare parts. The 6.2's were in military blazers and trucks before the H1's.
I think any of the options you are considering will require familiarizing yourself with the shortcomings of the drivetrain and being prepared to deal with them up front.
BTY a friend picked up a wrecked Penske truck at auction. He paid a little over 3K for a truck with a Cat engine (25k miles) and Allison auto tranny. He wound up removing the box and installing a 5th wheel for towing his toyhauler. He has less than $10K in it including all repairs, paint, etc.
70 Goat
74 Ventura
63 Cat
56 GMC
et al.
Old 02-15-2012, 12:22 PM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
One trick I learned my first summer over here is that Humvee's love to not start (or die while running) when it gets hot out. Didn't take long to figure out that dumping a bottle of cold water over the injector pump will get it to fire right back up. Can't tell you how many soldiers I amazed with that trick.
Mike
