Old 02-25-2012, 12:33 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Default 69 GTO Frame Off
I am well into my latest restoration - a 69 GTO frame off.
My question is what color is the bottom of the body supposed to be? I thought it was supposed to be black. One buddy says body color, but that is his Mopar mind talking I think. Please help set the record straight.
Yes I will post pics as soon as I get some from the shop.
Thanks John
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 02-25-2012, 01:10 AM
tom s tom s is offline
the 2 I have done were blk.Tom
Old 02-25-2012, 01:38 AM
getmygoat's Avatar
body color is mopar. gtos were black with body color overspray.....if you do a search, there is a lot of info already on this site
Old 02-25-2012, 03:44 AM
richard sargent richard sargent is offline
As far as I know they were all black except one plant was red oxide, not sure what plant that was.
Here's a post about this subject and picts of my Fremont car with factory over spray
http://forums.maxperformanceinc.com/...d.php?t=691162
Old 02-25-2012, 10:21 PM
notime's Avatar
notime notime is offline
All were black that i know of except framingham plant. Framingham usually had red oxide on floor with body overspray and i think the arlington plant usually had more body color on floor than others.
WWW.SUPERCARCREATIONS.COM
Old 02-26-2012, 05:58 PM
69 RA GTO's Avatar
69 RA GTO 69 RA GTO is offline
John,
I am glad you posted this question as I was going to as I am close to getting my 69 body blasted and was looking at which epoxy primer to use and what color. I am going back and forth whether to use SPI brand epoxy primers or PPG DP line epoxy primer.
I am thinking and please correct me here of going the red oxide over the entire body and inside the complete shell, and then shooting Black for the underside and frame. I agree that the underside most of the time is black as every picture of original undersides seem to be black with various degrees of over spray. As for the inside of the shells it appears to be red oxide as every original car and pictures I have seen, you can clearly tell it is red oxide with color over spray. As for the exterior I always see red oxide primer under original paint cars as they are stripped down or where they have sat outside for years and years and the paint wears down to expose red oxide.
What are every ones thought here? I will find some pics I have save thru the years for examples.
www.69judgeregistry.com
Documenting ALL 1969 Judge and Ram Air GTO cars. If you have one of these cars we would love to hear from you
Old 02-26-2012, 06:24 PM
69 RA GTO's Avatar
Some pics
Name:	Burg Original Floors.jpg
ID:	276441   Click image for larger version
Name:	Crystal 69 Unrestored Body 4.jpg
ID:	276442   Click image for larger version
Name:	Crystal Floor Pan Original.jpg
ID:	276443   Click image for larger version
Name:	Warwick Judge Original Floors.jpg
Old 02-26-2012, 06:27 PM
69 RA GTO's Avatar
Pics 2
Name:	Mayfair Maze Underside.jpg
ID:	276445   Click image for larger version
Name:	Arlington Build Judge Underside 3.jpg
ID:	276446   Click image for larger version
Name:	Original Arlington Build Judge Underside.jpg
ID:	276447   Click image for larger version
Name:	Original Warwick Blue Floor .jpg
Old 02-26-2012, 06:29 PM
69 RA GTO's Avatar
Pics 3. I thought I had more but this is all I could find. Anyone else have original pics of undersides, insides, exteriors?
Name:	Original Warwick Floor 1.jpg
ID:	276449   Click image for larger version
Name:	Original Judge Stripe Driver F.jpg
