I have a 79 Trans Am with the 4sp. I took out the 100 mph speedometer & put in the new 150 mph one - rear gear is original 3.23 as well as the trany - can anyone tell me if I need to switch speedometer gear at the trany & what No# teeth that would be? Thanks bunch.
You should be OK, If you did not alter either the rear end ratio, or the Speedo drive gear in the trans, it should be as accurate as the original speedo.
The only wild card is what the driven speed of both Speedo's are. Without knowing that I can't get any more accurate. If the ratio is the same on both speedo's (and I think it should be) it should work as well as the original.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
