Old 03-07-2012, 12:12 PM
Gator67's Avatar
Gator67 Gator67 is offline
Default 67 dash pad studs and nuts
I have a dash pad I plan to re-dye and use in my car, but I can't seem to remove a nut on one of the studs...the nut just spins at the bottom and won't catch a thread even if I pull up on it. I've snapped a stud on one of these before, and don't want that to happen on this one because the pad is in perfect shape. Any trick to doing this or is it even necessary to remove the nut when installing the dash pad?
Old 03-07-2012, 12:40 PM
george kujanski's Avatar
Are you describing the sheet-metal-type nuts on the pad studs that are used in the glove box area?
George
Old 03-07-2012, 12:42 PM
Gator67's Avatar
Yes
Old 03-07-2012, 12:48 PM
Old Goat 67's Avatar
I'd cut the nut itself off with a Dremel tool.
