Old 03-18-2012, 04:18 PM
emather1's Avatar
emather1 emather1 is offline
Default 1969 GTO 500Hp 455 $13k firm
To see pics of the car click here: http://s823.photobucket.com/albums/z...%20%20GTO/
She's a little dusy in the pic's, but she is brand new!
1969 GTO project car
500hp 455 w/0 miles
built TH400
built Ford 9" rearend w/ 3.5 gears and an Auburn posi
Vintage Air A/C and heat unit
Rockford Fosgate CD player
new fenders
new quarter panels need installed
new interior kit minus seat covers and foam (was looking for late model seats)
Started a frame off resto/mod and then came along my two girls which equals no GTO time.
Frame has been stripped and painted
new suspension
new Torq thrust wheels
new Cooper Cobra tires
all chrome plus extras
lots more new and used parts- all of my GTO parts go with the car I have one whole wall in my garage that is nothing but GTO parts and auto body supplies .
The rear window channel needs fixed,1/4s put on, and interior put in. I was waiting on the interior until I got the rear window channel fixed and 1/4s put on, but no time. the 1/4's don't need replaced just the wheel wells, but I got the 1/4's for the same $$ as wheel well patch panels so I got the whole thing.
I have been building this car to handle anything so it's built tough. I don't want to sell it, but she needs a new home.
I have $27k in this car as she sits so I will not go lower than $13,000
For everyone that keeps asking to buy just the engine it will cost you $6,000
you can email or text me after 3pm for questions or pics 417-684- five five eight zero
Thanks for looking
When in doubt, floor it.
Old 03-18-2012, 07:26 PM
tom s tom s is offline
specs on the engine please.Tom
Old 03-19-2012, 04:09 AM
emather1's Avatar
455 block 30 over
stock crank
Eagle H-beam rods
Speed Pro coated pistons 9.8:1 compression
Edelbrock Aluminum heads
Edelbrock Performer RPM intake
HarlandSharp roller rockers
Speed Demon 750 carb
Hooker ceramic coated headers w/stages 8 fastners
ARP fastners throughout
COMP Cams Grind Number P XE274H-10
Intake Duration at 050 inch Lift-230
Exhaust Duration at 050 inch Lift-236
Duration at 050 inch Lift-230 int./236 exh.
Advertised Intake Duration-274
Advertised Exhaust Duration-286
Advertised Duration-274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio-0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio-0.491 in.
Valve Lift with Factory Rocker Arm Ratio-0.488 int./0.491 exh.
And I am sure I am forgetting some things.
Old 03-27-2012, 10:38 PM
emather1's Avatar
bump
Old 04-08-2012, 02:47 PM
emather1's Avatar
BUMP
Old 01-02-2013, 10:28 PM
emather1's Avatar
Still available
Old 01-08-2013, 01:58 PM
taalltheway taalltheway is offline
Who has built the engine? Have you dynode it? I would be interested in the engine but i a not happy with the facts that is has no mileage on it. Usually problems from a fresh build show up within the first 2000 miles....i would like it more if it had some miles on it.
Old 01-08-2013, 02:47 PM
emather1's Avatar
A local engine builder here in Missouri. It was built exactly like one that Carcraft built. It made 501 HP and torque was 586. I can't help it that the car isn't road ready yet. It does have a couple hours of run time on it tho. I'd prefer selling the set, really don't want to split them up.
Old 01-08-2013, 03:18 PM
OK, if that does not work, get back to me...
