Old 03-24-2012, 11:52 AM
Dragncar Dragncar is offline
Default Gerotor oil pump ?
I read in another thread that someone is making a alternative to the Titan oil pump.
As cast iron gerotor oil pump, does anyone know something about this?
All we need is a iron gerotor oil pump like you can get for a FE Ford.
There is a big gap between the old spur pumps we have and the Titan.
Old 03-25-2012, 09:20 AM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
Thumbs up
Troy,
Tom Whilhite makes it. It is a nice piece. I have pics of it somewhere. The nice thing is you do NOT need a custom oil pan!
I have his number at the shop. Maybe someone else will be kind enough to post it.
Ace
Am I glad I got out of the business I was in? HELL YEAH!!!
Old 03-25-2012, 12:48 PM
Todd1035's Avatar
Todd1035 Todd1035 is offline
Send a message via AIM to Todd1035
Id be interested in seeing pics of it, and the contact info. Thanks...Todd
Old 03-26-2012, 12:23 AM
Purple Goat Purple Goat is offline
Not sure how clear these will be.
Old 03-26-2012, 08:37 AM
73 TRANSAM 73 TRANSAM is offline
Any links or price for one of this? Thanks.
Old 03-26-2012, 10:15 AM
lakefect lakefect is offline
why has this been kept a secret?
more info please
Old 03-26-2012, 10:24 AM
$50bird's Avatar
$50bird $50bird is offline
I called them this morning the pumps go for about $500
Here is his web site not to much info about the pump but if you call him he is happy to answer any questions.
http://www.wilhiteperformance.com/index.html
Old 03-26-2012, 10:40 AM
tiacguy's Avatar
tiacguy tiacguy is offline
Smile pump pics
Toms pump pics. I have others if interested. It is a highly modified billet ford pump. Although it can be run in a stock oil pan it would benifit from a small kickout being put in the right side of the pan as the pickup is next too/close to the pan side wall. no big modification. I talked to Tom at lenght about this pump and he stated at the time he and a few of his race buddies were running it with excellent results. The Butlers were doing testing for him also. I havent talkted to him for awhile and Im not sure were hes at with marketing it.
Ive had pemrmisson from Tom to post pics and info about this in the past. Scott.
Name:	Oil Pump 1.jpg
Old 03-26-2012, 10:55 AM
Todd1035's Avatar
That looks like a sweet pump, is it rated at a higher volume than a 54D? Does it have a bearing supported shaft?
Old 03-26-2012, 01:16 PM
Not what I am after. 500$, why not buy a Titan.
That is a nice looking billet piece.
Why cant someone cast us a gerotor pump that looks like a FE pump. No extra pan mods, nothing.
Just a more reliable, better designed pump than a spur pump.
A 150$ simple cast iron pump.
There is a market for them. They would sell.
Old 03-26-2012, 10:07 PM
Tom McQueen Tom McQueen is offline
Maybe. But the reality is there are plenty of suppliers out there that could do it, and they arent doing it. So, maybe not. I doubt the real market demand would cover the initial costs of production.
Old 03-26-2012, 10:27 PM
BOP was supposed to do one awhile back. Out of the same stuff their gears are made of I think ?
Old 11-29-2012, 07:12 AM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
Any real world results with this pump yet??
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 11-29-2012, 07:58 AM
Brian Baker's Avatar
more info please
I don't think it's so much of a "secret" than it is Tom is not a regular here on PY (if he's here at all) and racers modifying existing parts to work with something they weren't originally designed to goes on all the time. In other words, I don't think Tom was looking to market it, just build it so he could have something that would work for him without going to a heavily modified or expensive race pan...and if a few others can get in on it, that's cool too.
Old 11-30-2012, 04:08 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
The last I knew, Langer was "getting by" with a $20 Melling pump. Makes me ponder- why would any Pontiac owner "need" a different pump type? Although Langer spins his a little tighter, the iron blown-alky engine I ran for a couple of seasons saw 8,200 RPM everytime out, with a Melling pump.
Old 11-30-2012, 08:13 PM
taff2's Avatar
taff2 taff2 is offline
I was thinking the same thing Jack, I used an ordinary Melling pump in my last engine(and there's one in my new turbo combo) and spun that to 7 grand every run ,hundreds and hundreds of runs over a period of about 5 years without any oil related problems. Why fix something that isn't broke? And $500 for an oil pump? Come on!
Old 12-01-2012, 02:02 AM
Steve Barcak's Avatar
Jack, There are valid reasons that a $20 pump will be terribly inadequate in some applications.
A nitro motor needs 100-150 psi at idle at the hit or will destroy bearings. A Titan is fully adjustable and expandable. I have 3 of them. 2 of them are the expanded nitro versions.
You would even set up your pan to adjust your oil pessure with the pan on should someone need that.
Another application would be an endurance/marine application. My Pontiac powered jet boat ate oil pumps. They do not like high temps for long periods.
If you are N/A and drag racing, I would guess the $20 pump would do the job but, I am not going backwards, will stay will my 3 Titans.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 12-01-2012, 11:19 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
DFL coated help?
Skip Fix
Old 12-02-2012, 03:13 AM
Originally Posted by Steve Barcak View Post
... You would even set up your pan to adjust your oil pessure with the pan on should someone need that...
You mean... like the setup I built into the Tri-Power engine sitting in my GMC? Melling pump with relief spring seat adjustment brought out through side of the pan; works great.
Old 12-02-2012, 10:13 AM
mysticmissle's Avatar
Jack that sounds interesting Any pictures
