Old 03-24-2012, 05:20 PM
gitgo gitgo is offline
Default Upper ball joints
I just got my new upper ball joints from Kanter.the shaft will not go all the way down on the spindel. anyone else had this ?
Old 03-24-2012, 08:17 PM
GaryK's Avatar
GaryK GaryK is offline
I do not Like Kanter so I do not know what they sell but in order for me to get the upper ball joint into the spindal, I use a floor jack under the lower control arm to compress the spring to raise the spindal up and push the upper ball joint down into the spindal.
Hope this helps.
Gary
Old 03-24-2012, 11:18 PM
Default upper ball joints
no it is like the taper is wrong
Old 03-25-2012, 01:50 AM
mechanickeith's Avatar
If it wont go in, then they are wrong!! Call kanter & explain the issues with it. See what they say.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 03-25-2012, 09:31 AM
beemergary's Avatar
I'd take some measurements of the old one if you still have it. Thinking wrong size or different tapper. They sent me some wrong parts once and probably where ball joints. They made it right. I do remember that part of it.
Old 03-25-2012, 12:52 PM
Doug Doug is offline
I think that the degree of taper on ball joints is generally standardized (seems like it is 1/8" per inch?). However, if you get the wrong size they won't insert correctly.
Since you ordered parts for a 63, I would be curious as to what their part number is for the "incorrect" ones they sent you. I bought a 63 Kanter kit a couple years ago and I didn't have any fitment problems.
P.S. You can buy (from whom?) inserts to adapt smaller diameter ball joints to a larger sized spindle hole. The last time I saw these adapters listed they were about $20/pair as I recall.
Old 03-25-2012, 07:19 PM
Can you post pics of the affending ball joint/A arm ??
Keith Collier
Tech advisor
POCI.org
Old 03-25-2012, 10:37 PM
beemergary's Avatar
The last ball joints I got from Vintage Auto Parts Denver Co. 800 426-5911 877 882-7462 The invoice says 1-$20.00 But it seems like I would have wanted a pair. 1 or a pair I thought it was a good price.
Old 03-26-2012, 12:02 AM
That is a good price!! Thats more than half off what kanter wants for one!
Keith Collier
Tech advisor
POCI.org
Old 03-26-2012, 02:38 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
Where are they made?
Old 03-29-2012, 07:20 AM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
What was the out come?
Old 03-29-2012, 01:20 PM
I took front end to a rod shop .They confirmed the ball joints were too long.Called Kanter wait and see what they will do.
Old 04-04-2012, 10:16 PM
The second set were too long also.Was told to put washers to shim the spindle to the grease boot.
