Old 03-30-2012, 10:21 PM
Kell's Avatar
Kell Kell is offline
Default Frame connectors question
At some point if I get into Autocross, I assume I will need frame connectors. My front clip is disassembled right now and I just installed the new poly radiator support bushings.
My question is, if I am going to install frame connectors at some point, will I need to install solid body bushings, now is the time to do that I suppose? I already did the other body bushings with new poly as well, and they are much stiffer than my rotted out stock! But I guess I could always redo them if need be. Just trying to think ahead.
thanks
Old 03-30-2012, 10:28 PM
Kell's Avatar
test for signature
Old 03-31-2012, 02:02 AM
Bl1tzw1ng Bl1tzw1ng is offline
Yup do it now. The poly ones kinda suck anyways so it's like killing 2 birds with one stone.
Old 03-31-2012, 06:14 AM
cnc's Avatar
cnc cnc is offline
Yep do the bushing THEN the Connectors OR both at the same time...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 03-31-2012, 10:03 PM
Bigger is Better's Avatar
Bigger is Better Bigger is Better is offline
Yes go solid now. If you think aboout it the rear of the subframe connectors will be welded/bolted directly to the structure and if the front mount is attached to a subframe that moves you will eventually crack the welds. Anyways if you want to reduce flex with subframe connectors it goes hand and hand.
I like the ones from Dave at Pro-touring fbody and the ones from Global West.
Johnny
1980 455 TA
Autocross/Hillclimb
Powered by SD Performance
http://youtube.com/watch?v=Xc5rpSGwXlM
Suspension by www.pro-touringf-body.com
