Old 04-04-2012, 03:29 PM
carpoor carpoor is offline
Default Cowl tag help...
I have done several searches, must not be using the correct wording. I am trying to find information on how to see what the trim tag will reveal.
This past Monday I helped a friend pick up a 72' Lemans. The car is very original, shows just over 63K on the odometer. Was last registered in 1989, the title was issued on 02/12/1987 and the odometer reading on the title is 58,524. So 63K and some change doesn't sound unreasonable. It has factory AC, PS, PDB. White on white, appears to have had a vinyl top at one time. Has 14X6 Rally IIs, but may not have come with them. 350 2bbl, column shifted TH350.
The trim tag reads as follows:
ST 72-23537 A BDY
TR 252A5218 411 H PNT
12A 110145 750154
Thanks in advance!
Old 04-04-2012, 03:53 PM
Welcome to PY!
The 2 door LeMans hardtop was built at Lakewood (Atlanta GA plant). Body was built 12A (1st week of Dec '71).
the paint code, 11 is cameo white , H is a pewter colored vinyl top
Trim code 252A is ivory vinyl bench seat.
Original 14x6 rally II wheels for '72 LeMans will code KT next to the valvestem. If was ordered with the cheap optional handling pkg and D98 rally II wheels, the wheels will be 14x7 KS's & there will be a 7/8" rear swaybar under the car.
Old 04-04-2012, 04:53 PM
Judge273's Avatar
Judge273 Judge273 is offline
Sounds like a nice classic! Pics always help too....
Mike/Illinois
Old 04-04-2012, 07:26 PM
Thanks for the reply. It has no rear sway bar or boxed lower arms. I'll check the wheels tomorrow when there is more light.
I do not expect to find any build sheets. The gas tank and straps have been removed, and are long gone. The same with the carpets & headliner, they are also MIA. The front door panels are still there, and I have heard of a build sheet sometimes being stashed behind them.
The plan is to build a Lemans GT tribute to race in the pure stock muscle car drags. It's going to be a 400 4bbl, muncie 4 speed, and either 3.90 or 4.10 gears. I had never even heard of a Lemans GT until doing some research here. I had only heard of the GT 37s. It should make a very neat and unique car that will draw a crowd wherever it goes.
1972 Chevelle SS 2dr hardtop 454 LS5 4 spd - "Pure Stock"
1969 Chevelle 2dr hardtop L72/M20 - my "retirement" project.
1968 Chevelle 2dr hardtop 6.0/80E - pro tour-ish
1972 Monte Carlo turbo 6.0/TH400
2001 Silverado RCSS LQ4/80E swapped, cam, headers, FBO.
1972 E lCamino SS AFR headed 454/TH400 - the old man's project
Old 04-04-2012, 07:32 PM
Have pulled quite a few '72 Lakewood buildsheets from behind the drivers doorpanel.
Old 04-05-2012, 12:27 PM
2002Z4CSS's Avatar
Sounds like a nice car!
1971 Pontiac GT-37
Old 04-05-2012, 03:48 PM
I just looked at the wheels, all four of them have a distinct "KT" stamped on them next to the valve stem. So they might be original to the car. Are they worth anything? Ideally, we'd like to get a set of 15X7 Rally II's for the car. Not worried about what code they are, etc.
My friend Chris who owns the car registered yesterday, he goes by 722LemansGT. Here's a link to the thread he posted with a few pictures: http://forums.maxperformanceinc.com/...d.php?t=694952
Hopefully he uploads a few more, it's torn down quite a bit more since he took the original pictures Monday afternoon.
Old 04-05-2012, 04:32 PM
Thanks to 'ol Pinion head for the tip on the build sheet. I Just found it, it's mostly intact and legible.
From what I can see...
DLX BELT GROUP - option code illegible
TNTD GLASS - option code illegible
FLOOR CARPET - option code illegible
ROOF DRP MLDG - maybe a B80 to the left of it?
G84? BODY SIDE MLDG
CO8 PEWTER TOP
RECESS WIPER - option code illegible
C?? AIR COND
D35 O/S RR V/MIR
GQ1 STD AXL RATIO
GU7 278 AXL RATIO
JL2 P/BRKSFT D.S
L30 ENG 350 2BBL
M38 CRC TRANS
NB5 SINGLE EXH
N30 DLX STRG WHL
N41 POWER STRG
N98 RALLY II WHLS
PK2 G78X14 WW
P06 WHL TRM RINGS
U05 DUAL HORNS
U25 RR COMP LAMP
U27 IP COMP LAMP
U?? AM/FM RADIO 7312922
U8? ?? SPKR
UR/FS??
L/M 2DR CPE HDTP
LWR 11 CAMAEO WHITE
TOP PEWTER ?????
IVORY INTERIOR
VK1 DEL ??????
V31 F BPR GUARD
V32 R BPR GUARD
Charged to: Order Number
PROCTOR & PROCTOR INC. A43907
216 N MONROE ST Zone Dealer
TALLAHASSEE FLA 32302 17 248
Old 04-05-2012, 04:51 PM
72LemansGT's Avatar
72LemansGT 72LemansGT is offline
Cool it's a Florida car, that's pretty neat.
One day this will be a nice car!
http://i874.photobucket.com/albums/a...1333553267.jpg
Old 04-06-2012, 01:37 PM
Keith Seymore's Avatar
Off the top of my head, air conditioning is C60.
Body side molding might be B84 (it was used in later years as a base body side molding)
Carpet might be B30, with B32 front mats and B33 rear mats.
Tint glass is A01 (all windows) or A02 (windshield only)
U80 is rear seat speaker.
U69 is AM/FM; U58 is AM/FM stereo
Drip molding is B80
Not sure on the belts.
Sorry for skipping around a bit; most of these codes we still use today.
K
'63 LeMans Convertible
'63 Grand Prix
